Battery options
Old Sep 11, 2020 | 09:13 PM
locomex696's Avatar
locomex696
Lightbulb Battery options
just completed my 1st build. Just as I thought i will need to replace my battery. looking at xs power for a replacement. What battery made you happy and kept up with your build. What options are out there. what should I be looking for when making my final decision.
driving
SD 1200.4
SD 800.4
Fosgate 400.4
Old Sep 11, 2020 | 09:33 PM
cpbedor's Avatar
cpbedor
A stock battery is more than enough for what you're running. You won't need anything special. There are multiple options for lithium batteries, some more expensive than others. I have a Braille lithium and my voltage gauge doesn't budge even when I'm pushing hard.
Old Sep 11, 2020 | 10:07 PM
Moto Mike's Avatar
Moto Mike
Loco...If you have the cash I would definitely go lithium...I have the Anti gravity ATX-30 and I luv it ...even solved my starter kick back issue! It has a reserve feature, that if you run it down it shuts off and has enough reserve power to start your sled...$330 at MotoMummy! Batteriesplus has a Hyper Sport Lithium for around $220 w/ coupon!
Old Sep 11, 2020 | 10:52 PM
locomex696's Avatar
locomex696
Which Braille lithium and how many watts is your audio build?
So we have Braille, Anti and Hyper. to choose from, what are the determining factor to choose besides the jump start on the Anti gravity. I'm afraid to make the wrong choice and run out of juice 100 miles from home simply because i was listening to my music. Will listening to my music while riding kill the battery after a while?
Old Sep 11, 2020 | 11:22 PM
locomex696's Avatar
locomex696
Thoughts on the XS Power batteries?
Old Sep 11, 2020 | 11:56 PM
cpbedor's Avatar
cpbedor
The downside of lithium is that if you're playing music with the bike off and you run it down, it's done. It's a very sharp cliff. It goes from good to done and if you run it too far the battery will not recover. That's the bonus of what Mike mentioned is that that anti gravity will stop the drain before you fry the battery. You'll never run out of power when the bike is running for a rider's setup. A traditional battery you can play in the parking lot and you'll see voltage dropping but even at 10V the bike will probably still fire. Just a much longer sloped cliff. Lithium batteries charge faster and puts less strain on the charging system so even when you're hammering a song on the road, the charging system keeps you at 14.4V without a dip. I have the Braille G30H 24aH. It runs two 1200.4s, a 1600.1, a 400.4 and a DSP along with heated grips and heated gear when needed. The Braille AGM battery I had prior to the lithium would dip down below 13v while riding when running music hard and it pissed me off so i pulled the plug on that and bit the bullet. I had my doubts but I've been pleasantly surprised
Old Sep 12, 2020 | 12:15 AM
Moto Mike's Avatar
Moto Mike
There are all kinds of options for Lithium battery's available for bikes, I just named a few...prices range from $1500 to $220..I just bumped up an older thread for you to check out a lot of info in there except for the nay sayers!
Old Sep 12, 2020 | 12:33 AM
SBates08's Avatar
SBates08
You're not going to kill your stock battery while riding period. My previous upgrade was 3,000 watts on the stock style battery and could easily play for 30 minutes or more without worrying about the bike cranking. No more watts than you're pushing, you're way over thinking things.
Old Sep 12, 2020 | 11:09 AM
madhunter60's Avatar
madhunter60
What charger/ battery tender are you using with the atx?
Old Sep 12, 2020 | 11:58 AM
locomex696's Avatar
locomex696
I don't do any parking lot shows at all ( zero) so would a stock battery replacement work. my tones will only be playing while my bike is rolling.
