Budget install
Old Sep 18, 2020 | 04:54 PM
Juice's Avatar
Juice
Originally Posted by Knucklebuster27
What is “2 amp?
Also the speakers you listed to run straight off the factory radio are 4 ohm, so should these be wired in parallel so the resistance is only 2 ohm?
This is a flash that will turn on all 4 outputs of your bike and have the flattest curve. 8 speaker 2 amp...
No do not run speakers off the head unit that is why I put the 500/4 (4 channel amp)
Juice
Old Sep 18, 2020 | 04:56 PM
Knucklebuster27's Avatar
Knucklebuster27
5th Gear
Juice
Got it, thanks.
Old Sep 18, 2020 | 05:01 PM
Knucklebuster27
5th Gear
Jl mx500/4 389.00
https://www.crutchfield.com/S-qxW4tt...IaAoUSEALw_wcB
Audio legion 149.00 (run these straight up)/ Stereo Fairing
https://www.rhynoaudioworks.com/coll...cycle-coaxials
Dayton DSP 150.00
https://www.parts-express.com/dayton...audio--230-500
Faital fe200 100.00 ( parallel and bridge 2 channels of amp to these) Lowers
https://www.usspeaker.com/faital%20pro%206fe200-1.htm
Amp install kit 40.00
https://www.amazon.com/Motorcycle-am...s%2C177&sr=8-9
Juice
8 ohm faital’s?
Old Sep 18, 2020 | 05:03 PM
Juice's Avatar
Juice
8 ohm faital’s?
Yes..
When ran in parallel it will be a 4 ohm load so you can bridge the amp I recommended, they will split the 250 watts from channels 3 and 4 that are bridged.
Juice
Old Sep 23, 2020 | 08:35 PM
Knucklebuster27
5th Gear
Juice
The Audio Legions come with crossovers for the tweeters, should I install them?
Do I need adapters to fit the 6.5’s into the batwing fairing?
Can you give me settings for the Faitals to “band-pass” in their wheel house?
Old Sep 24, 2020 | 09:02 AM
Juice's Avatar
Juice
Juice
The last set I installed I used the cross overs.
Juice
Old Oct 14, 2020 | 12:15 PM
Knucklebuster27
5th Gear
Juice
The JL amp only shows the output configuration you suggested (uppers straight up, lowers parallel and bridged)with a single channel input.
I assume I need a dual channel input from the DSP to the amp so I can band pass the lowers correct?
And would this be a 3 channel?
Old Oct 14, 2020 | 01:34 PM
Juice's Avatar
Juice
yes, 3 channel. yes you can run 2 channel off the dsp (link the channels in the DSP software) if you have them available or run a "Y" type rca from the dsp to the amp.
Juice
Old Oct 18, 2020 | 07:16 PM
Knucklebuster27
5th Gear
Juice
Wow! It sounds awesome. I did go with the DSR1 instead of the Dayton because American Hard Bag pre tuned the inputs for me. I high passed the uppers and band passed the lowers but will still do some more tweaking I’m sure. It actually hurts my ears.
Thanks for your help.
Old Oct 19, 2020 | 08:45 AM
Juice's Avatar
Juice
Glad it worked out.. Those speaker are pleasant to listen to. Not harsh and made for bikes, pretty warm for a 6.5.
Juice
Jayadev Dange
Audio Systems
Apr 15, 2020 03:43 PM
wamps98
Audio Systems
Mar 7, 2020 09:38 AM
hophead61
Audio Systems
38
May 19, 2018 09:28 AM
Dtroy
Audio Systems
Apr 16, 2017 05:44 PM
Tweeter2148
Audio Systems
13
Dec 30, 2014 09:39 PM
