Budget install
Can I get a decent setup for $1k? If so, wha are your suggestions?
Stinger amp and MMATS seem popular.
Also my fairing speakers are not 6.5’s, I assume from my reading that they will fit, but do you need adapters?
Thanks in advance
https://www.crutchfield.com/S-qxW4tt...IaAoUSEALw_wcB
Audio legion 149.00 (run these straight up)/ Stereo Fairing
https://www.rhynoaudioworks.com/coll...cycle-coaxials
Dayton DSP 150.00
https://www.parts-express.com/dayton...audio--230-500
Faital fe200 100.00 ( parallel and bridge 2 channels of amp to these) Lowers
https://www.usspeaker.com/faital%20pro%206fe200-1.htm
Amp install kit 40.00
Juice
Dayton DSP 150.00
https://www.amazon.com/Motorcycle-am...s%2C177&sr=8-9
Juice
What are your thoughts on a Mmats MD4110 intead?
Dayton DSP 150.00
Juice
I never used a MMAts amp, Im sure it will get the job done too.
Juice
Also the speakers you listed to run straight off the factory radio are 4 ohm, so should these be wired in parallel so the resistance is only 2 ohm?
Right speaker to channel 2
Lowers parallel and bridged to ch 3 and 4
Juice
