DSP-408 question
Old Nov 5, 2020 | 06:30 AM
ToddOH's Avatar
ToddOH
Default DSP-408 question
Going to be wiring this thing up soon and have some questions.
1) Is there a benefit to using a LOC vs. speaker level inputs?
2) I have the 8/2 flash. Do I need to use both the front and rear signals or can I just use the fronts?
Thanks fellas!
Old Nov 5, 2020 | 01:30 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Todd I don't know anything about Rushmore stuff but I would hate to do without fader control. If you just use the front you wouldn't be able to fade with your thumb. I would think that if you used the front and rear outputs you could retain fade control.
Hopefully a Rushmore guru can help you with the output level question.
Old Nov 5, 2020 | 03:59 PM
marshallb's Avatar
marshallb
What processor?
Old Nov 5, 2020 | 04:28 PM
SBates08's Avatar
SBates08
Originally Posted by marshallb
What processor?
It's in the title.
Old Nov 5, 2020 | 04:33 PM
SBates08's Avatar
SBates08
Todd most use low level inputs because they have that option with an aftermarket HU. Personally I don't think you'll notice a difference between the 2. You can use both front and rear inputs but I have personally never used anything other than the front. After tuning the system to my liking I've never felt like I needed to have the fader involved.
Old Nov 5, 2020 | 04:52 PM
marshallb's Avatar
marshallb
Originally Posted by SBates08
It's in the title.
Oh duh man I'm off today.
Old Nov 5, 2020 | 08:04 PM
InthewindMN's Avatar
InthewindMN
Thanks fellas!
fade won’t work with a 8/2 flash.
Old Nov 5, 2020 | 09:15 PM
marshallb's Avatar
marshallb
Fade is overrated imao
Old Nov 5, 2020 | 09:57 PM
teedoff65's Avatar
teedoff65
That's what I thought as well for the 8/2 flash. I went out and checked and the fader function is there and the slider moves on my stock HU with that flash. I dont have rear speakers, but wondering why the slider "works" or is even enabled with this flash.
Old Nov 6, 2020 | 06:28 AM
ToddOH's Avatar
ToddOH
I checked mine and the fade option comes up but it doesn't slide. I knew this when I had the flash done so don't know why I even asked about the rear outputs. I suppose I could hook them up incase I decide to change my flash for the fade option.
