speaker pod plugs
Old Nov 8, 2020 | 12:38 PM
Chunky Monkey's Avatar
Chunky Monkey
Default speaker pod plugs
I was changing out the speakers in the pods and adding rear deck lid 6x9s and an arc 600.4 amp. I am using the Biketronic line levelers and all is good. My wires that come out of the pods and to the harley plug is just to short to clip and tie into the amp. So I was going to buy the female plugs and extend the wires to the amp. Anyone know where I can get the plugs?
TIA
The Chunk
Old Nov 12, 2020 | 05:26 AM
Dsm Limited's Avatar
Dsm Limited
The wiring to the pods should be able to reach the line leveler if you cut the ties that route the wires. If not, you can purchase the plugs and terminals from HD or Drag Specialties.
Old Nov 16, 2020 | 11:16 AM
Chunky Monkey
The ones from the back of the stereo or head unit go to the line levelers and plug directly into the line levelers. I need the female plug that goes into the pod plug to give me a little extension to go to the amp.
Old Nov 16, 2020 | 11:59 AM
SBates08's Avatar
SBates08
That's easy....run new speaker wire to the speakers. Done!!!
Old Nov 16, 2020 | 12:27 PM
Chunky Monkey
I do not want to pull the pods off to get to the back of the speakers. As you know a real PITA.
Old Nov 16, 2020 | 12:42 PM
D-Roll's Avatar
D-Roll
1st Gear
these are the ones I used to make my harnesses
Harley Front Molex Connector
Harley Rear Molex Connectors
then I used these to wire directly to my amp simple and clean. I flash my bike so no more line levelers
​​​​​​​4 pin molex to amp ​​​​​​​4 pin molex to amp
Old Nov 16, 2020 | 12:45 PM
Chunky Monkey
Originally Posted by D-Roll
these are the ones I used t make my harnesses
Bingo that’s what I was looking for. Thanks
Bike medic
Audio Systems
Mar 10, 2017 10:18 PM
Tn.Heritage
Audio Systems
Jun 28, 2015 09:00 PM
soniccbr
Oct 19, 2013 01:19 PM
soniccbr
Oct 15, 2013 04:14 PM
yank721
Audio Systems
May 14, 2013 12:21 PM
