Replacement for Rockford Fosgate speaker lid kit (Boss Audio)
Old Feb 18, 2021 | 07:13 PM
RadarLove84's Avatar
RadarLove84
6th Gear
Default Try Double RMS than rated. Tested Already with RTA
Originally Posted by scott_0
I wouldn't expect much out of the speakers for sure, 175w rms for the pair, as said, if you plan on replacing the speakers, depending on the quality of the rest of the kit, may be worth a try.
Old Feb 21, 2021 | 02:13 AM
Rcloud72's Avatar
Rcloud72
Originally Posted by SuaveEnvie
Does the Boss sticker come off good??? i may ask my audio guy how much he can get them for. Speakers will get junked, but the grill and template is a better deal.
yes the boss badges come off easily just hit them with a little heat from a. Heat gun and they pop right off. I took mine off and Installed a small bar amd shield badge and it looks like it came that way
Old Feb 21, 2021 | 07:39 AM
Aj89's Avatar
Aj89
could you post pics of the lids and the link you got the badges?
Old Feb 22, 2021 | 05:53 AM
Rcloud72's Avatar
Rcloud72
I got the badges in a cheap set of eBay grills and not sure if I can find the link but I’ll try. I may have some pix of grills and if not will get some today.
Old Feb 22, 2021 | 02:07 PM
05sportie's Avatar
05sportie
I can’t wait to try this kit, I couldn’t believe the quality and for the price. Only thing I didn’t like is how the put the grommets on the wrong wiring part. But that’s a easy fix
Old Feb 22, 2021 | 02:14 PM
Aj89's Avatar
Aj89
I have a brand new kit for sale. $280
Old Feb 22, 2021 | 06:55 PM
05sportie's Avatar
05sportie
I just got mine in the mail today
Old Feb 22, 2021 | 08:19 PM
Chris Mancini's Avatar
Chris Mancini
was your logo raised I hit mine with heat and the logo didn’t move
Old Feb 22, 2021 | 09:44 PM
Rcloud72's Avatar
Rcloud72
no my logo was actually set in an indention set in the grill. I put high heat from a heat gun to the back of the grills for a few seconds ( close to ten seconds) and then from the front took a small flat head screwdriver and popped it off. Both came off super easy
Old Feb 22, 2021 | 10:01 PM
Rcloud72's Avatar
Rcloud72
yeah I saw the rubber grommet on the wrong side of the wiring harness but tbh I didn’t use any of the wiring that came with the kit only Bc I already had a set of lids on the bike ( the metra pair) with MMats 6x9s I’m them. So all I did was take the entire metra lid off, used the templates to cut the holes and then changed hardware on my factory lids that had been on a shelf. I already had 12 gauge wiring ran so didn’t see the need to change it out. The harness that comes with the kit is well made though. And it looks like stinger wire. The same kind a lot of shops buy in bulk. I plan on using it on my lowers to rewire them soon and drop either the prv carbon fibers or some GZ red baskets.
if only someone would hurry up and come out with 8” lids for the wet head models!!!
