Speaker wire
Old Dec 17, 2020 | 10:42 AM
SteveLepine57's Avatar
SteveLepine57
Default Speaker wire
Guys,
2020 Street Glide Special here. I just added a tour pak with the speaker pod which come with a nice wire harness to unplug rear speakers when I want to remove it. What's the gauge of the OEM wires?
I'm adding a Stinger SPX700X4 and MMats speakers. Can I use OEM wires? The wires coming out of the Stinger harness are pretty small so they look similar. I don't mind going with bigger wire but is it really worth since it's not a huge amount of power and short distance?
Thanks,
Steve
Old Dec 17, 2020 | 11:11 AM
travelingypsye's Avatar
travelingypsye
Originally Posted by SteveLepine57
Guys,
Thanks,
Steve
I would run all new speaker wire and connections if it were me. Nothing worse than going down the road, hitting a bump and loosing one side or the other from cheap HD connectors. .
Old Dec 17, 2020 | 11:32 AM
FrenchieM's Avatar
FrenchieM
Guys,
Thanks,
Steve
To answer your question yes you can use the stock connector and wires from stinger. Would new ones be better sure and you could make your own quick disconnect. I’ve never had any connector come loose on my bike after going over bumps.
Marks57
Audio Systems
Sep 11, 2018 11:28 AM
ccrohl
Jun 18, 2017 02:18 PM
bladeguy
Audio Systems
Apr 16, 2016 07:28 PM
TwoBlue02
Audio Systems
May 24, 2014 08:30 PM
89FLHT
Sep 10, 2008 12:42 PM
