GZ 6.5 coaxial
Old Feb 5, 2021 | 06:01 AM
  #31
SBates08's Avatar
SBates08
Originally Posted by USAproud
Exactly. Not many 6.5" speaker period that can handle 400 watts without a dsp.
There aren't many 6.5" speakers that can handle that kind of power with a DSP. This one won't handle that much with a DSP either. 300 watts would be max or pretty dang close to it.
Old Feb 5, 2021 | 08:30 AM
  #32
cshocker's Avatar
cshocker
I have a brand new set of GZ coax for sale if you set it for 400w. Let me know!
Old Feb 5, 2021 | 09:17 AM
  #33
Hoyt 1911A1's Avatar
Hoyt 1911A1
Shoot as we had mentioned before I get good sound out of the GZs in my batwing with only 150 clean watt with a tune on them from a DSP. They sounded OK with a flat signal going to the amp but didn't have much punch, just loud and clean. I just dropped the mid frequencies a little bit and it added some punch.
I guess in some cases when folks need to run big wattage to these things hearing loss, wind and exhaust noise may be a factor.
Old Feb 5, 2021 | 09:21 AM
  #34
Thatdude596's Avatar
Thatdude596
Will let you guys know here soon how they sound. I'm going to match my gain to 39.5 volts while running test hrtz and multimeter. Should be sending around 330 watts from guys who do this everyday. Shut off low pass and bass boost and run high pass around 85 Hertz
It's only a set of speakers fellas. Push em to the limit!
Old Feb 5, 2021 | 09:22 AM
  #35
Thatdude596
If I blow these I will buy a set of diamond amps next
Old Feb 5, 2021 | 09:27 AM
  #36
teedoff65's Avatar
teedoff65
What does the amp have to do with pushing too much power to a speaker that cant handle it??
Or speaker brand for that matter, if that's what you meant. Too much power is too much power.
Old Feb 5, 2021 | 09:32 AM
  #37
cshocker's Avatar
cshocker
Originally Posted by SBates08
Brother you can take their comments and run with them if you choose but I'm here to tell you, if you run 400 watts to those speakers, without a DSP you will blow them to hell quick fast and in a hurry!!!! Without a DSP in the mix I would push no more than 250 watts per speaker. This is coming from someone that's not selling you jackshit and has nothing to gain. Carlos knows his **** but he's gonna get a lot of folks in deep water that think they can emulate what he does in his videos. You cannot run that much power to them without a DSP. Period.
Bingo! And all of his videos, he says he's "sending them 400w". Well he has his amp set to 400w, but I haven't heard him turn the volume up all the way to actually get 400w to them. It's a little misleading. He also a professional who's job is to not blow speakers, so he specially knows how to set them up. Guys needs to stop thinking can just throw a punch of power at something because they saw a video of a guy doing it.
Old Feb 5, 2021 | 09:34 AM
  #38
SBates08's Avatar
SBates08
Yeah it's just a set of speakers but you were warned here first. Drink that koolaid brother. Those shops are depending on you.
Old Feb 5, 2021 | 09:36 AM
  #39
Hoyt 1911A1
One thing to consider is how do you want these speakers to sound? If you want as much volume as possible then feed it watts. If you find that you want some more low end lower the wattage going to them so you can lower the crossover point. Crossovers in the 80s probably sound fine but I left mine set at 50 with 150 watts going to them and really like lows these things produce. I can still crank them plenty loud and can hear the bass guitars as well as the kick drum while out on the highway. The other six speakers I have in play have higher crossovers since they have to overcome more distance and wind noise than the fairing speakers do.
As always ymmv.
Old Feb 5, 2021 | 09:45 AM
  #40
teedoff65's Avatar
teedoff65
I need to stock up on some speakers....need some beach money!
