cb antenna
Old Feb 25, 2021 | 06:18 PM
kramdua's Avatar
kramdua
Default cb antenna
probably been asked but here goes.
2010 harley ultra classic. i took tour pack off and made a bracket and just bought a universal car antenna for my am/fm. now i am thinking of making a cb antenna mount and wanted to know if i can use a universal antenna?
thanks,
mark
Old Feb 25, 2021 | 06:27 PM
Hammz's Avatar
Hammz
thanks,
mark
Short answer: No.
If you expect to both transmit/receive with the CB, you'll want a CB antenna that is resonant on the CB band frequencies: 26.965Mhz to 27.405Mhz. The coax will need to be 50 ohm impedance as well (typical AM/FM coax uses 75 ohm impedance coax).
Old Feb 25, 2021 | 06:30 PM
kramdua's Avatar
kramdua
thanks,
i was going to take the stock antenna off the tour pack but to remove it would be a major job due to them using sealer around the rear lights. if that makes sense. unless you know of a better way.
mark
Old Feb 25, 2021 | 06:38 PM
JMJOHN's Avatar
JMJOHN
Sponsor
Hamms ,,,,,
see if one of these would help you ,,,, J&M License Plate Mount CB Antenna Kit with 2’ Staff (jmcorp.com)
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Feb 25, 2021 | 06:53 PM
kramdua's Avatar
kramdua
also thanks for the antenna specs.
Old Feb 28, 2021 | 03:38 PM
DwayneH's Avatar
DwayneH
Veteran: Canadian Forces
Originally Posted by Hammz
Short answer: No.
What he said.... Also, ensure you tune the antenna to the radio for optimum SWR. Unless you want to blow the finals in your radio. For me, I am considering installing my FTM-400XDR but it has a large face, and it's not water proof.
Old Feb 28, 2021 | 03:56 PM
kramdua's Avatar
kramdua
thanks for the tips. i was able to remove the complete antenna assemble from my tour pack so i made a mount for it. now it is hooked up like it was from the factory.
Hickey33
Feb 21, 2017 05:04 PM
Ultraboy105
Jan 26, 2016 01:30 PM
Keystone
Audio Systems
Apr 3, 2015 06:41 AM
sgl0226
Nov 22, 2013 05:35 PM
Topcop
Dec 6, 2011 07:39 PM
