06 FLHTCUSE Speakers
Old Feb 26, 2021 | 01:41 PM
Financial Freedom's Avatar
Financial Freedom
1st Gear
Default 06 FLHTCUSE Speakers
I have a 06 Screamin’ Eagle Ultra Classic Electra Glide, I removed the touring pack and placed the amp in the saddlebag. I used it that way and the front speakers work fine. I just installed 6x9 Pyle Marine speakers in the lids and connected the wires but the speakers have no sound. Has anyone done this or have any recommendations as to what I should do?
Edit
Old Feb 27, 2021 | 10:04 AM
JMJOHN's Avatar
JMJOHN
Sponsor
Financial Freedom ,,,,,
when you say you connected the wires to the new saddlebag lid speakers ,, which wires?
the speaker wires that used to go to the rear pod speakers?
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Feb 28, 2021 | 08:48 AM
Financial Freedom
1st Gear
The speaker wires. I removed the original speakers but kept the wiring and harness. I also connected the new speaker wires to original harness and plugged them in. No sound
Old Feb 28, 2021 | 10:45 AM
JMJOHN's Avatar
JMJOHN
Sponsor
that is for the rear output channels of the original amp correct?
the wires that originally went o the rear trunk pod speakers
Old Feb 28, 2021 | 02:44 PM
Financial Freedom
1st Gear
yes, the original amp and output channels for the rear
Old Mar 1, 2021 | 04:32 AM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
Edit
may be a stupid question, but has to be asked...check the fader??
Old Mar 1, 2021 | 12:52 PM
JMJOHN's Avatar
JMJOHN
Sponsor
Iron cross ,,,,
good question ,,, he should check front/rear fader setting on the radio, as if all 4 speakers worked before he relocated the amp, they should work now ,,,,,,
on his CVO ,,,, the radio controls the front/rear fade within the rear mounted amp ,,, not actually inside the radio ,,,
Old Mar 3, 2021 | 07:41 AM
Financial Freedom
1st Gear
Iron cross ,,,,
thinking about it, I did check the faders. Now the radio I currently have is a stock radio but it came off of a 2010 street glide. My original radio looks exactly the same but some internal pieces inside need to be repaired. So that means the radio I have now, may not be set to work 4 speakers. Does that sound about right?
Old Mar 3, 2021 | 07:59 AM
SBates08's Avatar
SBates08
You're dealer will need to enable the rear speakers. If that HU is compatible with your Boom system it should work.
Old Mar 4, 2021 | 07:29 AM
Iron Cross Audio
Former Sponsor
The rear speakers are always active, The only thing the dealer turns on is the fader. Even with the fader not turned on, he should still get rear channel outputs
