Low fluctuating hum?
Old Mar 25, 2021 | 02:30 PM
wilburbill's Avatar
wilburbill
I had a hum issue after installing my new head unit and amps. Turned out to be a ground issue. I tied all grounds from head unit, amps, and DSP all together and that fixed it.
Old Mar 25, 2021 | 03:01 PM
hamah's Avatar
hamah
That makes sense. The #1 cause of noise in grounds is probably due to voltage differentials between the various components. Tying the grounds together (ensuring you're using the same ground) eliminates that. This is also why a crappy RCA interconnect often proves to be the issue. It also ties the chassis grounds together. To eliminate engine noise the manufacturer of the amp the OP on this thread uses recommends common grounding on pg 3 of this manual (in this case the noise is present with the motor off though).
Old Mar 25, 2021 | 03:23 PM
SBates08's Avatar
SBates08
Just for shitz n giggles, where was the common ground that you used for all of those components?
Old Mar 25, 2021 | 03:37 PM
travelingypsye's Avatar
travelingypsye
Old Mar 25, 2021 | 03:39 PM
cshocker's Avatar
cshocker
You boys go ahead and discuss all this technical humming. I'm going to figure out what all that humming noise is coming from my gf's bedroom.......
Old Mar 25, 2021 | 03:49 PM
teedoff65's Avatar
teedoff65
well obviously you're not in there so it must be a hum of boredom. Lol
Maybe she needs to be ground properly.
Old Mar 25, 2021 | 03:54 PM
mrmagloo's Avatar
mrmagloo
I had a ground issue on that new fangled toilet sprayer thingie my wife wanted. I heard screaming one morning and came running in. The thing went into hyperdrive or something and she had bidet water squirting out her ears.
Still searching for that ground strap.
Old Mar 26, 2021 | 07:33 AM
wilburbill's Avatar
wilburbill
I kept the ground from the amp at the battery but ran an extra ground wire from the radio and DSP to the ground connection at the back of the amp thus tying all grounds together.
Eric Steward
Audio Systems
17
Mar 27, 2019 10:54 AM
Paradoxicated
Audio Systems
22
Oct 15, 2018 07:59 PM
lowlifefalcon
Audio Systems
May 3, 2015 02:17 PM
nivensid
Jun 23, 2014 08:55 PM
badazzpred
Audio Systems
22
Aug 30, 2013 09:06 PM
