Ground zero red baskets
Old Mar 24, 2021 | 08:08 PM
SCORPION111674's Avatar
SCORPION111674
Default Ground zero red baskets
Currently running
4-hertz 6.5 neo (upper and lowers)
2-hertz 8's neo (lids)
2 diamond shallow mount in grills
2 hertz st25a neo in lids
2-800.4 SD AMPS (CH 1&2 FRONT AND REAR TWEETS/CH 3&4 UPPERS AND LOWER-LEFT AND RIGHT) 2ND AMP-8'S BRIDGED CH 1&2 ANC 3&4
GROUND ZERO DSP
CHANGING HERTZ 6.5 FOR GROUND ZERO RED BASKETS 6.5 UPPER AND LOWERS
TAKING ONE 800.4 OUT OF FAIRING AND ADDING 1200.4
ADDING 2-GROUND ZERO 10'S IN BAGS WITH A SD 2400.4
What do you think of this set up and what is best way to run it. Have bike wired for 2400.4 to go in bags already.
Old Mar 24, 2021 | 08:13 PM
SBates08's Avatar
SBates08
First question is are you sealing the bags or at a minimum using buckets on the 8's in the lids?
Old Mar 24, 2021 | 08:22 PM
SCORPION111674
That is one thing I want to find out, what is best because I know I have the 8's in lids and 10's in bag sharing the same air space. I put some dynamate in to see what kind of sound I could get. what kind of 8 cups can I get to cover the 8's. I don't want to seal the bags because I want to still be able to use some of my space for travel.
@SBates08
Old Mar 24, 2021 | 08:44 PM
SBates08's Avatar
SBates08
They cannot share the same air space. Here's a link to some 8" baffles.
Amazon Amazon
Old Mar 24, 2021 | 09:00 PM
SCORPION111674
@SBates08 ok thanks after you said that, I went and found the same ones. what about the rest of the set up. What do you think?
Old Mar 24, 2021 | 09:05 PM
SBates08's Avatar
SBates08
If I'm reading it correctly you're running the red baskets off a 1200.4. Is it a 2 or 4ohm version?
Old Mar 24, 2021 | 09:32 PM
SCORPION111674
@SBates08 it is a 4 ohm. right now I have the 8's on a 800.4 bridged and the current 6.5 and all 4 tweets on the other 800.4.
Old Mar 24, 2021 | 09:33 PM
SCORPION111674
@SBates08 I will be taking one one of the 800.4 out and putting the 1200.4 in its place.
Old Mar 24, 2021 | 09:46 PM
SBates08's Avatar
SBates08
That's why I was asking. You'll need the 1200.4 (2ohm) version for those red baskets. Parallel bridged so you can get more watts to those speakers.
Old Mar 24, 2021 | 09:55 PM
SCORPION111674
@SBates08 so if I do that, then how should I run the 8's and the 2 sets of tweets. one is a set of diamonds and the other is st25a neo?
