Yellow basket question
Old Apr 4, 2021 | 02:36 AM
JMJIN's Avatar
JMJIN
Default Yellow basket question
Hi freshly upgraded to a pair of yellow basket coax in the faring, powered by a cv b54 bridged. Running them at 200w with a dsr1 for crossover/eq and a rockford 2 speaker flash.
Question is: with the crossover set at 80hz 12db if i turn up to my max volume (where I set my gain) I seem to get what sounds like a max excursion or some sort of nasty distorted pop sound on big kick drum hits or similar low frequency sharp sound. I thought that was a fairly conservative crossover for these speakers? Am I just running into an issue of the speaker itself not being broke in enough?
Old Apr 4, 2021 | 04:59 AM
travelingypsye's Avatar
travelingypsye
First max volume on any HU will distort and distortion will blow the speakers especially with high gains. What bike and HU do you have?
Old Apr 4, 2021 | 09:49 PM
JMJIN's Avatar
JMJIN
6.5gt, 18 RGS. When I said max volume I meant my new max of 4 notches from full where I set my amp. I don't think it's signal distortion, but I'm a bit beyond my element. The electrical side of audio is simple due to my job/ education but the audio specific things I don't know.
Old Apr 5, 2021 | 06:38 AM
travelingypsye
Try backing your gains down and taking it to your max volume then taking your gains up until you hear distortion. Then back them down a tad. That is a start.
Old Apr 5, 2021 | 12:41 PM
cshocker's Avatar
cshocker
Did you set gains with multimeter? And after the DSR installation?
Old Apr 5, 2021 | 05:52 PM
av ultra's Avatar
av ultra
My 1200 4-4 was super sensitive to gains, I made a couple of mistakes that might help you
#1 my test tune wasn't-5, I used the straight 1000db, and the second time when I used the right db test tune i forgot to set my bass & treble flat, so # 3 attempt was golden, just a slight bump on the gains **** and I would go from 28 to 36, not sure how you would set your dsp for voltage at speaker, I don't have one.
Old Apr 5, 2021 | 06:03 PM
Makdaddy's Avatar
Makdaddy
This is really a false statement.
Distortion is based of off many factors.
My experience with HU and digital media (test signal) rarely show distortion with new HU,s maxed.
Please take that statement with a grain of salt
Old Apr 5, 2021 | 07:24 PM
teedoff65's Avatar
teedoff65
my hu showed distortion at an even lower volume! Was measured with a DD 1
Old Apr 5, 2021 | 09:38 PM
travelingypsye
Every head unit I has tested with a dd1 boom, aftermarket or both have shown distortion above a certain mark. As distortion IS based on many factors, above a certain set volume you are NOT gaining volts in volume but distorted signals from a hu. So I will stand by my statement. I did miss read the op’s original statement and thought he ran the volume to max and max volume on any hu will distort or at least in EVERY hu I tested.
Old Apr 6, 2021 | 11:51 PM
Makdaddy's Avatar
Makdaddy
Are you guys testing just the signal from the HU? Isolated from Amplifiers DSP and other sources of noise?
Odd to be finding HU distort on a clean Digital test tone.
I would suspect other issues, or maybe the HU are not of good quality?
But a brand name like Kenwood or Pioneer should not show distortion at Full volume on a clean signal as outlined.
Just my 2 cents and experience
Ill be installing a rebuilt ARC 600 this week
Ill see if I cant get a Video up as I tune
