Gain settings and Bluetooth music
Old May 13, 2021 | 08:30 AM
USAproud's Avatar
USAproud
I have always set my gains using BT since that is what I always use for playing music
Old May 13, 2021 | 09:01 AM
mcdc1224's Avatar
mcdc1224
Think I will use the Bluetooth to set them and see how it goes..........I'm with SB, something's not right
Old May 13, 2021 | 09:26 AM
teedoff65's Avatar
teedoff65
My concern is...using BT to set gains, if you use another cleaner signal, will that adversly affect your system and possibly introduce distortion? I would think the cleaner, best signal possibly to set gains would be the best to use. Or maybe I'm thinking about this all backwards. lol
I just know I can tell a significant difference in volume and sound quality when I switch from usb/android auto or thumb drive music over to Bluetooth. Volume is lower and doesn't sound as clean.
Old May 13, 2021 | 09:40 AM
hamah's Avatar
hamah
you want the loudest source to set gains. The reason being you won’t get into clipping at the same volume for lesser sources. Having said that if you put **** in you get amplified **** out.
Old May 13, 2021 | 09:45 AM
teedoff65's Avatar
teedoff65
Yeah thats how I was thinking it should be. Just wasn't explaining it well i guess lol
Old May 13, 2021 | 09:51 AM
mcdc1224's Avatar
mcdc1224
deleted
Old May 13, 2021 | 10:04 AM
hamah's Avatar
hamah
Originally Posted by mcdc1224
deleted
This is pretty much what I was saying. I've never used a DMM to set gains (I'm too lazy, stupid, or both). I HAVE used an o-scope when the opportunity presented itself. When I did, I would use a test tone and set the source volume just shy of clipping and then I'd set the gains. Otherwise, I always went by ear. Set gains low, crank source volume until distorted, back off volume until clean, set gains until distorted (or ears bled..whichever came first), back off gains a tad, and button it up.
Old May 13, 2021 | 10:12 AM
teedoff65's Avatar
teedoff65
You're setting gains based on max non distorted volume or 3/4 in most cases with the BOOM hu's. But you'll very rarely play any music at that max undistorted volume for extended periods of time, so using a mm is just fine in 99% of our cases I think. If you're competing or just like learning and tinkering with audio, I can def see using all those fancy gadgets. lol
Old May 13, 2021 | 10:17 AM
mcdc1224's Avatar
mcdc1224
Agree with that statement!! My issues are, I just like to tinker and learn.....sometimes its very costly and painful!!
Old May 13, 2021 | 10:45 AM
hamah's Avatar
hamah
yeah, I've not normally been a fancy gadget guy, my ears were the best tool for me. Only reason I don't use a DMM is that I never had to in the past (if I really needed it I had an o-scope I could use). Also, a DMM meant using a calculator
