HU Flash, DIY?
Old Jun 12, 2021 | 03:53 PM
dkyser's Avatar
dkyser
Default HU Flash, DIY?
Can you flash your HU yourself, if so what is needed and how difficult is it?
May be worth investing if you are headed down this rabbit hole and may be trying different things.
Old Jun 12, 2021 | 04:06 PM
mcdc1224's Avatar
mcdc1224
Not a stock GT or GTS.....will need to see a HD dealer, RF dealer or someone that has a TR device
Old Jun 12, 2021 | 04:07 PM
rsking45's Avatar
rsking45
You can do it yourself if you buy the flashing tool, technoresearch radio flashing kit. They are around 300.00. I had my flashed with the Rockford Fasgate flash. Sounds 100 times better
Old Jun 12, 2021 | 07:07 PM
Back-n-Black's Avatar
Back-n-Black
Would be worth buying if it wasn't locked to a single bike
Old Jun 12, 2021 | 07:41 PM
mcdc1224's Avatar
mcdc1224
Yep. 300 bucks is pricey for a flash
Old Jun 12, 2021 | 09:50 PM
dkyser's Avatar
dkyser
Newbie question, can you flash your bike with different settings or are you pretty safe going with just one flash like the RF flash and be done with it.
Old Jun 12, 2021 | 11:15 PM
rsking45's Avatar
rsking45
Yes it would.
Old Jun 12, 2021 | 11:23 PM
rsking45's Avatar
rsking45
ARe you adding a amp?
Old Jun 13, 2021 | 04:02 AM
mcdc1224's Avatar
mcdc1224
If I were going to run a DSP on a stock GT or GTS, I would go RF and be done. If I have a DSP, I would go with the 8/2 flash and be done. If you have the tuner, if can change it as many times as you like...
Old Jun 13, 2021 | 07:57 AM
dkyser's Avatar
dkyser
Yes I am adding an amp and probably a dsp.
