Speaker placement
Old Aug 23, 2021 | 02:35 PM
smittyrock3's Avatar
smittyrock3
Default Speaker placement
2021 Road Glide. I currently have WDXMOTO6CD speakers in the fairing driven by a SD400.2 I just purchased a SD400;4 my plan is to mate the 400.2 to my Mmats PA601CX and set the voltage to supply 140 watts crossover probably around 100hz and the 400.4 to the Motos set the amp around 200 - 220 watts specs say they can go as low as 80hz, I also recently purchased a set of lowers. so my question is which set would you recommend going in each location and why? Running BT355 from stock GTS unit without a flash if that infromation helps.
jumpnbean
Audio Systems
Feb 15, 2021 11:08 AM
cfave
Audio Systems
Jun 11, 2020 06:59 AM
wilburbill
Audio Systems
Nov 27, 2019 08:24 AM
GFFGBeast
Audio Systems
Jan 18, 2018 06:45 PM
rs03371
Audio Systems
Feb 15, 2014 10:18 PM
