Amp Recommendations ?
Old Oct 11, 2021 | 06:46 PM
memphisharley's Avatar
memphisharley
Originally Posted by Fireball Jack
my SD1200.4 2 ohm powering 2 gz coax and 2 Mmats 6x9's is so loud and clear I can not get above 50% volume until i get to freeway speed. It has been rock solid.
i would appreciate it if you would share how you have these 4 speakers wired.
thanks
Old Oct 11, 2021 | 08:58 PM
cshocker's Avatar
cshocker
thanks
Bridge/parallel 6.5’s to channel 1/2 and bridge/parallel 6x9 to 3/4.
Potential for 300w per speaker.
Old Oct 11, 2021 | 09:01 PM
cshocker's Avatar
cshocker
Originally Posted by Badbagger
Still up in air lol. Made changes to my original plans. The SD are so good size wise, the failure rate scares me. Although come to find out it’s due to fan placement on 1200’s and up..
Its more than a fan issue. I had a 400.4X go bad. Just from powering some horns. I know a other 400’s that have gone out.
My 2400.4 was dead out of the box. Zilch, zero, nothing out of 2 channels immediately after taking wrapper off.
Old Oct 11, 2021 | 09:54 PM
Badbagger's Avatar
Badbagger
Damn it sure is. I’m back to Euphoria Xpert then. Bigger than the SD 800.4 but power wise close. 2 6.5 Coax in fairing bi amped and a set of 6.5 mid range in lowers. Even with Lex Rivera rack I can fit one and dsp. 2nd will go in bag or TP. It is what it is. Will pickup small amp for horns on coax.
Old Oct 11, 2021 | 10:14 PM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
Default Euphorias
I’m looking at Euphoria EX4’s. I’m going to need 3. Thankfully I get a 20% military discount from Euphoria.
These euphorias ROCK. Led Zeppelin has never sounded better.
__________________
LONG RIDE SHIELDS
www.longrideshields.com
Old Oct 12, 2021 | 05:13 AM
Badbagger's Avatar
Badbagger
Thanks I here same thing elsewhere 👍
Budda109
Audio Systems
Apr 15, 2024 11:46 PM
bucko72
Audio Systems
26
Jun 21, 2021 07:10 PM
Will T
Audio Systems
Apr 2, 2019 12:20 AM
kjc
Audio Systems
Jun 18, 2016 02:57 PM
DTTJGlide
Apr 5, 2010 10:13 AM
