Almost there...
Old Dec 27, 2021 | 04:38 PM
  #81
memphisharley's Avatar
memphisharley
Originally Posted by hamah
You still need to make sure the HU is outputting a clean signal first.
this is really important as I found out the hard way. Andy mentioned it to me after he warrantied a set of GZ for me and I still thank him today.
Old Dec 27, 2021 | 05:53 PM
  #82
fastsoup's Avatar
fastsoup
No argument that starting out with a clean input signal when setting gains is important but how does using a test tone ensure that? You still need to make sure the HU is outputting a clean signal first. That signal could either be a test tone or music, depending on what method you prefer for setting your gains.
Well the O-Scope can confirm the head unit signal prior to setting the gains with the amp. Tap positive to the center of the RCA & the negative to the casing. I have always been a set audio by ear guy...but with a bike and all the sound it makes when running makes it tricky. I feel that with an O-Scope I will be able to go max, then compare that to the voltage (see what power the amp is actually putting out) and then go from there.
Old Dec 27, 2021 | 06:48 PM
  #83
hamah's Avatar
hamah
Originally Posted by fastsoup
Well the O-Scope can confirm the head unit signal prior to setting the gains with the amp. Tap positive to the center of the RCA & the negative to the casing. I have always been a set audio by ear guy...but with a bike and all the sound it makes when running makes it tricky. I feel that with an O-Scope I will be able to go max, then compare that to the voltage (see what power the aThe mp is actually putting out) and then go from there.
Get one of these:
BNC male to RCA female adaptors BNC male to RCA female adaptors
You can test the RCA cable at the same time you're testing the pre-amp output.
Old Dec 28, 2021 | 08:45 AM
  #84
fastsoup's Avatar
fastsoup
Get one of these: BNC male to RCA female adaptors You can test the RCA cable at the same time you're testing the pre-amp output.
Why spend the money...like I said...center of the RCA cable is positive and the casing itself is negative.
Here is a informative video demonstrating from start to finish.
Old Dec 28, 2021 | 11:28 AM
  #85
hamah's Avatar
hamah
https://youtu.be/9JWXQw5A8BU
That's a good video.
"Why spend the money?" Well, check out 5:10 of the video. Have you tried to clip the alligator clip on the end of your probe to the outer ground on an RCA plug? That inexpensive adaptor might turn out to be handy while you're trying to do the measurement inside the fairing...with the motor running. Most of my oscilloscope use has been on the bench where I had lots of space and access to vises etc. and yet nothing beats having the right attachments for your scope and keeping your hands free for other things. Just my $.02
Old Dec 28, 2021 | 11:47 AM
  #86
fastsoup's Avatar
fastsoup
"Why spend the money?" Well, check out 5:10 of the video. Have you tried to clip the alligator clip on the end of your probe to the outer ground on the cable? That inexpensive adaptor might turn out to be handy while you're trying to do the measurement inside the fairing...with the motor running. Most of the oscilloscope use over my career has been on the bench where I had lots of space and yet nothing beats having the right attachments for your probe and keeping your hands free for other things. Just my $.02
I totally understand what you are saying, but a 10ft RCA cable solves that...but yes...the right tool for the job is the only way to avoid excess effort.
Old Dec 28, 2021 | 12:14 PM
  #87
hamah's Avatar
hamah
Will that be the same 10' cable you use between the HU and amp? Probably not. It's nice to know that the cable you've used has no intermittent connection issue which is why you should include it when doing your setup (like you will with the speaker wire).
Old Dec 28, 2021 | 12:16 PM
  #88
fastsoup's Avatar
fastsoup
Valid point! 👌🏼
Old Mar 16, 2022 | 06:21 PM
  #89
fastsoup's Avatar
fastsoup
Howdy,
Getting ready to do a 6 speaker install (GZ YB in fairing - SX 165 Neo in TP & Lowers)
& started with my head unit (Kenwood KMRM328BT) and connected my oscilloscope to the RCA leads and I could not get the deck to clip @ a 1khz test tone. I then hooked up the subwoofer out with a 50hz test tone and that didn't clip either?? I then connected the FR speaker lead & ran the 1khz test tone and the oscilloscope showed clipping at 28 volume (35 max).
Could my pre-outs really send a clean signal regardless of volume?
Picture 3 is FR speaker at 27 volume - Pic 1 is 1khz at full volume & pic 3 is 50hz at full volume.
Old Mar 18, 2022 | 06:39 AM
  #90
Babyboy's Avatar
Babyboy
Howdy,
Your scope is not playing tricks on you. The Kenwood 328 HU is clean all the way to full volume with a 1k tone at the RCA outputs.
