A DSP isn't "essential" with a two speaker setup, but it will make those two speakers sound a lot better than they would without a DSP.
Let me fix that for you.
A DSP isn't "essential" with a two speaker setup, but it will make those two speakers sound a lot better (if you can learn how to tune them) than they would without a DSP
If I can learn how to tune them any simian based creature that has had less than a six pack to drink could learn to do a basic tune. At its most basic a DSP could be looked at as a graphical EQ. Once more knowledge is gained further functionality can be explored.
I thought a DSP isn't essential when running 2ch stereo system.
I'll start in a safe zone and work my way up.
Originally Posted by Hoyt 1911A1
I have an old CRT Tektronics scope from the early nineties that I would use from time to time. I finally decided to get a cheap handheld scope and was surprised at how well it worked. The sinewave was perfectly clear and easy to distinguish between clipping and clean. If someone has a scope that never shows a clean sinewave I would be suspicious of it.
He gets to the nitty gritty at about eight minutes into the video.
If you set the gains using this tool, I guess it doesn't matter what the actual wattage coming off the amp to the speakers is...because it's a verified clean signal, yes? So if I use this tool on the 400.4 and get it set clean, it could be delivering 200 watts to the SX 165 Neo's but it doesn't matter because it's verified with no distortion? Am I getting this right?
That is correct. You're not setting gains for a target voltage but for a sine wave that is not clipped. You will be setting the gain to the max possible before the amp starts to clip.
You may see some harmonics/harmonic distortion (blurred or fuzziness) in the sine wave depending on the quality/sensitivity of the scope and probe used but that is not the same thing as clipping.
Well that seems to me the clear way to set amplifier gains. Interesting to hook up a MM after and see what the actually voltage will be.
Question.....Wouldn't one want to send a specific voltage to their speakers? Say you have an amp that puts out 250watts of clean power and your speakers are rated at 100watts, why would you send them more than they can handle?
Someone can chime in if I am wrong but the rated power is set by manufacturers to prevent bone heads from sending massive amounts of unclean wattage to a speaker and blowing it.
The reason I mentioned above that it would be interesting to use the O to set clean gain (amp never sending dirty power) and then checking the voltage with a MM.
I would assume that even if a speaker is rated for 100 watts, but you set your gains with a O and its a clean 200 watts and doesn't clip, the chances of blowing that speaker with a dirty signal gets cut down...or am I way out to lunch?
The voltage is clearly shown on the oscilloscope by adding up the height of the sine wave. Also a lot of them nowadays also have a voltage readout on the side along with other pertinent info.
