Almost there...
Old Nov 2, 2021 | 12:05 PM
  #41
Hoyt 1911A1's Avatar
Hoyt 1911A1
Any decent oscilloscope should be able to give you a good enough waveform to where you can see the sinewave flatten out on the peaks. That is the point of clipping.
Old Nov 2, 2021 | 12:22 PM
  #42
hamah's Avatar
hamah
^^^ this
Teedoff, I mentioned in that other thread that the pics showed a signal that wasn't clipped. A clipped signal is painfully obvious with very clearly defined plateaus that will "round out" (a subjective term depending on screen resolution) with peaks appearing as you back off on the gain setting. Even the cheapest low-end o-scope is useful and easier to use than a DMM+calcualtor/cheatsheet.
To those that don't already have a DMM and/or a wife with excellent hearing (btw, ears are still the best way to set gains IMO) you should check out these low-cost oscilloscopes as they cost about the same to buy and are way easier to use. Oh, and these portable o-scopes can still operate as a DMM.
Old Nov 2, 2021 | 12:37 PM
  #43
fastsoup's Avatar
fastsoup
So if the 400.4 can do 200x2 @ 4ohms, that would be 400w, and the square root of 400, which is exactly 20.
So would set the amps gains to 20v per channel...yes?
Old Nov 2, 2021 | 12:58 PM
  #44
Fireball Jack's Avatar
Fireball Jack
20V would be 100W 28.3V will give you 200W
Old Nov 2, 2021 | 01:10 PM
  #45
fastsoup's Avatar
fastsoup
Thanks Fireball. So I'll set to 28.3V with the bike on, GZ X @ 80Hz & Neo's X @ 120Hz using a 1000Hz - 10DB test tone from Amazon Music & go from there.
Old Nov 2, 2021 | 01:38 PM
  #46
fastsoup's Avatar
fastsoup
With the 1K standard with my gains set to min. I was at 28V AC with the -5db I was able to get to start @ zero. They have been a few others, that have had to do the same. I think it is the flash and Harley HU.
Using an aftermarket head unit I hopefully won't have this issue.
Old Nov 2, 2021 | 01:52 PM
  #47
Circa58's Avatar
Circa58
Been watching this one.... but the Lumi 2021 I got will actually show a very slight fuzz on the top of the wave,,,,, if I set it at the same point my DD-1 says there is no distortion
So when I turn it down @ 1.5 volts then, the fuzz goes away... so I'll be doing more dialing in this weekend, I'll know for sure how close they are to detecting distortion at the same point in volts
Also, the Lumi displays the volts and the wave once it is set
Amazon Amazon
Old Nov 2, 2021 | 02:59 PM
  #48
teedoff65's Avatar
teedoff65
Originally Posted by hamah
^^^ this
I realize allthis...but my pics shows the sine wave at different gain settings....there was NEVER a smooth wave of any form. AGain, most likely the user....but after that I dont trust it to rely on when dealing with max watts on a speaker.
Old Nov 3, 2021 | 09:09 AM
  #49
Hoyt 1911A1
I have an old CRT Tektronics scope from the early nineties that I would use from time to time. I finally decided to get a cheap handheld scope and was surprised at how well it worked. The sinewave was perfectly clear and easy to distinguish between clipping and clean. If someone has a scope that never shows a clean sinewave I would be suspicious of it.
I got the scope that this fellow shows in his video and use it often:
He gets to the nitty gritty at about eight minutes into the video.
Old Nov 3, 2021 | 09:27 AM
  #50
teedoff65's Avatar
teedoff65
Set Amplifier Gain with cheap $40 Oscilloscope
Hoyt, thats the one I bought first and for whatever reason I dont understand.....a very knowledgeable guy here tried to help me get it working correctly, I couldnt use it....something to do with the freq range not enough.....like I said, I know very little about them. Anyway it wouldnt work with my set up so I returned it and got what I thought should be a better one.
o-scope o-scope
This one is the pics I posted in the other thread hamah is referring too. I guess I was expecting to see a smooth line until it clipped. To me that wasn't the case.
You can see how ugly those lines are. At 39v there shouldnt be any clipping and while there isnt a flat wave at the top, the rest of the pixelation going on scared me. Again, perhaps its how I have the scope set or something. Would love to figure it out and be able to use it in the future, but it also makes for a very good MM, so there's that.
