Im looking to install a system on my Road king 2021, just worried about the battery draining.
I have a razor tour pak with the Advanblack speaker lid (2 x 8" speakers + 2 tweeters) and the saddlebag 8" speaker lids + 2 tweeters
2 x speaker pods mounted on the crash bar for 6.5" speakers
The below is what im thinking. Could anyone advise if the battery and alternator will keep up or should i be looking at additional high output alternator and adding in a battery?
thanks in advance
2 x 6.5" speaker shttps://www.spaudio.it/midrange-extreme-neo-sp-6mm-neo-200-watt-rms-16-5cm-6-5-sold-as-unit.2.11.103.gp.631.uw
4 x 8" speakers https://www.spaudio.it/midrange-extreme-neo-sp-8mm-neo-250-watt-rms-20cm-8-sold-as-unit.2.11.103.gp.632.uw
4 x tweeters https://www.spaudio.it/tweeter-sp-tw18-25w-rms-1-pair-.2.11.1.gp.653.uw
You're gonna run 8 speakers and 4 horns off a 400 watt amp??
To answer your question, there are guys pushing way more watts than that on a stock battery. I have 4 6.5 speakers and two horns pushing around 1300 watts on my stock battery with no issues.
Gotcha. I dont wanna say that brand is good or bad, since I have no clue. Id still plan out your system to get enough watts to each speaker. based on those specs provided.
Do you have a suggestion on a Amp that would be suitable, I'll have to bite the bullet and pay the import tax & duty as not much available here.
