SPX700 input help please
Old Dec 13, 2021 | 09:30 PM
oly22's Avatar
oly22
Default SPX700 input help please
Hi,
I have been running an SPX 700x4 bridged to 2 channel powering 2 GZ 6.5s in my fairing of my 17 UL. I was using a BT line leveler from the speaker outputs of the factory head unit. Tonight, I removed the BT LL and connected the HU speaker outs directly to the amp in preparation of a RF flash. Cut off the RCA inputs and connected to the amp inputs. I turned on the radio to check my connections and the whole thing sounds terrible, muffled, distorted the whole works. I know that the RF flash flattens the factory sound curve but will it rectify this? Is there anything else that needs to be done with this amp to switch from RCA to speaker level input? Any recommendations would be greatly appreciated.
Thank you
Old Dec 13, 2021 | 10:50 PM
teedoff65's Avatar
teedoff65
See how it sounds once you get it flashed. If i recall, mine sounded like crap before it was flashed as well.
Old Dec 13, 2021 | 11:30 PM
hamah's Avatar
hamah
Did you reset your gains? If not you are overdriving the inputs and clipping.
Old Dec 14, 2021 | 08:09 AM
teedoff65's Avatar
teedoff65
Yes that too......after you get the HU flashed, you'll need to set your gains again.
Old Dec 14, 2021 | 12:55 PM
oly22's Avatar
oly22
Thanks! I did turn the gains way down before I turned it on to prevent damage. I will get it flashed before messing with anything else.
Fireball Jack
Audio Systems
Jul 12, 2021 08:27 AM
Timothy Rau
Audio Systems
Aug 26, 2019 02:05 PM
ThisIsCrazy
Audio Systems
19
Aug 4, 2014 08:24 AM
Mixter
Oct 18, 2011 10:12 AM
Q Hog
Mar 10, 2010 03:29 PM
