Audio install help
Old Dec 21, 2021 | 01:28 PM
teedoff65's Avatar
teedoff65
Originally Posted by cvofatboy65
Just listed the items I bought. Also thank you for the tip on running power to the battery
Right. Like I said, I've seen those grills with pre mounted horns. Still curious about the clearance. Would love to see an install pic once you're done, if you don't mind.
Old Dec 21, 2021 | 01:34 PM
cvofatboy65's Avatar
cvofatboy65
I can take a pic of the grills when I get home
Old Dec 21, 2021 | 01:36 PM
hamah's Avatar
hamah
I bought everything from 702 Motoring and have reached out to them a little while ago, waiting for a response. Mounting the amp and all that is easy for me just how to wire everything correct is confusing. I have all the plug n play connectors. They preset everything on the amp before sending. The horns come attached to the speaker grills already and they soldered the crossovers to the horns.
I've seen their site. They appear to have thought of everything you'd need (pics of how to mod speaker pods, different bolts to mount speakers, premounted horns, etc.). Looks like a nice package. Good luck.
cvofatboy65
When running the power to the battery did you run both wires down the same channel or split them. Any pics of the area to run them, i think i know where you mean
Old Dec 21, 2021 | 01:38 PM
cvofatboy65
Yeah, i got everything. Just the wiring confuses me. Except running power to the amp, that's easy
Old Dec 21, 2021 | 01:40 PM
cvofatboy65
Old Dec 21, 2021 | 01:41 PM
cvofatboy65
I just wish it came with some simple install instructions
Old Dec 21, 2021 | 02:06 PM
Fireball Jack's Avatar
Fireball Jack
Just take it one wire at a time. Power and ground to the battery. run the Mids next, Then the horns. Plug in your RCA cables and then your remote amp turn on. Make sure your gains are at zero.(counter clockwise). Put in your main power fuse and start 1K test tone and target voltage.
Old Dec 21, 2021 | 02:11 PM
cvofatboy65
What voltage should I see coming out of each speaker?
Old Dec 21, 2021 | 02:16 PM
cvofatboy65
They preset everything on the amp before sending it. But I could double check
