I just installed the SVT30L battery on my 2015 Harley Road Glide CVO. The bike has a factory alarm and I noticed a low drain on the battery from 12.87 to 12.6 over the last few days since install. I have not connected a charger to it. On the AGM battery I replaced, I used a Schumacher SP3 3 Amp Automatic Battery Extender / Maintainer. It is microprocessor controlled and has float mode which keeps the battery maintained when fully charged. Is that a charger I can use or would you recommend something else? Bike is ridden mostly on weekends. Thank you
