Dayton DSP Help.
Old Feb 2, 2022 | 06:01 PM
Fireball Jack's Avatar
Fireball Jack
Default Dayton DSP Help.
I fell in the rabbit hole. I bought a Dayton 408. This is in a RGU no tour pak speakers in play at the moment. I have a GT head unit RF flashed. Sd1200.4 2 ohm bridge parallel to GZ YB coax. Channel 3-4 Mmat 6x9 in lids. Any help with tuning the Gz's?
Old Feb 2, 2022 | 08:13 PM
teedoff65's Avatar
teedoff65
Anything specifically you're needing? Or just an overall tune for those speakers?
How many watts are you sending them?
Old Feb 3, 2022 | 06:54 AM
Fireball Jack
Thanks for the reply. Over all tune would be sweet. I am sending them 250W but can send 300W.
Old Feb 3, 2022 | 08:39 AM
teedoff65's Avatar
teedoff65
Gotcha. Im not good enough to advise on a over all tune. lol But I will say, with the dayton you may get some noise like turn pn pops and such. Mine did, as well as had a kinda whistle when turning off. I put a ground loop isolator in and fixed all of that.
If you set your gains properly, just get in there an play around with it. The biggest learning curve to me are the q settings for each channel.
Might be hard to find someone here on a forum to completely tune your bike though. Post up some screens of the settings you have now and im sure someone can comment whether they're good or not.
FYI, there are some guys that offer remote tuning for about 100 bucks. At least there is one guy I know thats local to me that will do that.
Old Feb 3, 2022 | 08:57 AM
Fireball Jack
Thanks for the advice! I will keep a USB cable hooked up and in the glove box seems like I have a few nights of playing coming up.
Old Feb 3, 2022 | 08:59 AM
Fireball Jack
Which Ground loop isolator did you go with?
Old Feb 3, 2022 | 09:15 AM
teedoff65's Avatar
teedoff65
I think it was
this this
one.
But could have been
this this
one.
lol I ordered one and it was on back order, so found the other and it came pretty quick. Just dont remember which was which.
Old Feb 7, 2022 | 01:16 PM
sponger's Avatar
sponger
run high level inputs to the dsp. Gets rid of noise and the need for a remote wire turn on. Run power and ground from dsp to distrobution blocks if using them. If not, run wires to battery.
Old Feb 7, 2022 | 02:36 PM
Fireball Jack
Thanks for the help!
Badbagger
Audio Systems
Jan 23, 2022 03:17 PM
Zekedoggg
Audio Systems
24
Jul 16, 2021 02:57 PM
converted1
Audio Systems
Jun 11, 2019 07:04 AM
Shakenbake31
Audio Systems
Jun 18, 2016 04:49 AM
remmag
Audio Systems
Jun 12, 2016 06:33 AM
