Turn signal noises through speakers.
Old Apr 9, 2022 | 07:55 PM
Oneshot660's Avatar
Oneshot660
Default Turn signal noises through speakers.
I need a little insight. I have a 2015 sgs. Factory radio, axxess line out converter,skar 400wattx4 amp, polk db652 6.5 speakers. I am getting a turn signal noise through my speakers. Only hear it when volume is turned down. I have tried 3 different sets of Rca's, 3 different loc's. I cleaned and added heavy duty ground strap from battery to chasis. I also have the amp grounded to the battery and a second ground in the fairing. The noise is not too noticeable if I do not ground the loc. But the sound is horrible when it is not grounded, besides the turn signal noise.But still can only hear it when volume is all the way down. If I put the 4 ways on it gets a bit louder. I have installed plenty of car audio systems and never had a problem like this. I do not have the bike started while I am trying to figure out what is causing the noise. I have it plugged into the battery tender as I am diagnosing. I am starting to think it is either the stereo it self. Or maybe to much power being drained from battery with it not running. I have done a lot of research on this issue , but everything I read says a ground issue. I have checked all my ground wires with a mulitmeter. Only 1 ground was .02 ohms. Which if I read correctly that is fine. The battery with out the bike started is at 12.5 volts. I also tried using the high level inputs on the amp with same results. I think I covered everything I have tried. Been trying for a couple days trying to figure this out. It probably would not bother most people, but I am the type, if I feel something is not right I keep at it. Somebody please tell me they have had this problem as well. Last minute adds as what I have done. I cut a pair of rca's and hooked to a speaker, the noise is there before the amp. I also cut the ground wires to the stereo and grounded them with thicker wire to battery. It is hard for me to believe 3 different loc's had the same problem.
Old Apr 9, 2022 | 08:21 PM
hamah's Avatar
hamah
It is a ground issue. Both the radio and amp should ideally be grounded to the same place to avoid any differences in ground potential. Try a GLI such as this one to go between the low-level output of the LoC and the input to your amp. While this won't fix the actual source of the noise it may very well make it inaudible or much less annoying.
Old Apr 9, 2022 | 08:31 PM
Oneshot660's Avatar
Oneshot660
I forgot to mention I did try a ground loop isolator did not help at all. I also multimetered all my ground lines.
Old Apr 9, 2022 | 08:47 PM
hamah's Avatar
hamah
hmmm. on speculation try moving the amp ground temporarily to one of the radio mounting bolts. (you typically won't see potential differences in grounds using a MM except in really bad cases). Sources of ground noise can be really hard to diagnose. If you can only hear the noise with the volume down and the bike not running it might be easier to live with it (I know it would drive my OCD brain over the edge but maybe you're like 98% of everyone else).
Old Apr 9, 2022 | 09:05 PM
Oneshot660's Avatar
Oneshot660
I will try temporarily moving the ground. And not sure I have ocd (I might ,not sure) but it is driving me crazy. It is why I have not put the front fairing back on yet, and been spending countless hours in the garage trying to figure it out.
Old Apr 9, 2022 | 09:07 PM
CoolBreeze3646's Avatar
CoolBreeze3646
May want to pull all your turn signal bulbs, clean the sockets and check for corrosion, then put a little dielectric grease in the ends of the bulbs where they go into the socket. You may have a resistance factor if there is a little corrosion in the bulb sockets causing the noise. Just spitballing here.
Old Apr 11, 2022 | 09:04 AM
teedoff65's Avatar
teedoff65
So the noise you hear you say is the turn signals? SO that mean it only occurs when you turn your turn signals on? Are you running any aftermarket turn signal processors? like the magic strobe?
How loud is the noise? Can you hear it when music is playing?
If you can get the noise to occur while you're standing there, start with each connection. Touch or move or even disconnect each RCA and see if the noise stops.
If its a constant low hum or buzz, that might just be inherent of your aftermarket amp/wiring or speakers. BTW check those speakers....does the noise come from both sides? If not, swap them with each other and see if the noise follows.
Old Apr 11, 2022 | 11:36 AM
Fireball Jack's Avatar
Fireball Jack
What bulbs are you using? Some LEDS will cause noise.
Old Apr 11, 2022 | 12:24 PM
Oneshot660's Avatar
Oneshot660
No after market processors. Yes turn signals and 4 ways. Make loud click. Brake makes a slight click. Both speakers make this noise. Not so noticeable after I turn volume up to 2. It is not the rca's. I have tried 4 pair now. So get this. 4 different loc's every one does not really do it till I hook up the ground wire for loc's. But with ground wire off the music sounds like crap. I have touched every connection I could with no change to noise.
Old Apr 11, 2022 | 12:25 PM
Oneshot660's Avatar
Oneshot660
Stock 1157 I tgink they are. Pulled all of them out and cleaned with no help.
