No sound after install
Old Apr 23, 2022 | 04:12 PM
Atomic Bagger's Avatar
Atomic Bagger
Default No sound after install
Finally got around to finishing the install of aftermarket amps and speakers in my '18 CVO Streetglide, and now no sound.
Stock HU, DSR1, 1200.4 Evox for upper and lower GZCF's, 800.4 Evox for saddlebag MMAT's.
Rockford Fosgate flash. Used American Hardbag "T" harness, front bypass plug, and rear bag harness.
All speakers pop if powered without delay, but nothing getting from HU to speakers. Took DSR1 out of mix, so it's, in theory, from HU to amp and nothing happening. Music source from thumb/flash drive and volume up a little.
Talked to American Hardbag tech a couple times yesterday, but they're closed today. I'm wondering if their harness may be pinned wrong for CVO?
Need some help.
Old Apr 23, 2022 | 09:08 PM
Dsm Limited's Avatar
Dsm Limited
Just off the top of my head.
Is your remote turn on wire hot with the key on?
Is the amp indicator light on?
Check that any slide switches on the amp are fully in position.
Old Apr 25, 2022 | 01:15 AM
travelingypsye's Avatar
travelingypsye
Try fm to see if there is at least static from the speakers. My guess is if you are getting a pop in the speakers then something is working. As DMS stated check remote wire and the switches on the amp. The memory stick may be bad or the hu may not recognize it.
Old Apr 25, 2022 | 09:13 AM
Atomic Bagger
I agree, that if there's pop at the speakers, then they're hooked to something. The amps turn on and I've tried Sirius, FM, AM, and the flash drive (which has been in there for two years), but still have zero sound. I swapped amps and still nothing.
American Hardbag is stumped, as well.
Old Apr 25, 2022 | 11:10 AM
teedoff65's Avatar
teedoff65
Stupid question, but is there a mute button in your DSR1 like many DSP's have? Ask me how I know this lol
Eh, reread your post and see where you tested without the DSR1.
Old Apr 25, 2022 | 12:34 PM
travelingypsye
Ok after thinking this thru, the pop is from the amp to the speakers, so the speakers are working. So check the output signal from the hu to the amp. You said you are using a AHB harness. so do you have the rca's off that going to the amp? Check those rca's. How do you have the harness hooked to the amps?
Old Apr 25, 2022 | 09:58 PM
hamah's Avatar
hamah
The T harness has high-level outputs on the RCAs. With the DSR1 in the signal path did you have the Input Level switch set to high? When you removed the DSR1 did you adapt the RCAs on the harness to use the high-level inputs on the amp(s)? Those amps only take low-level inputs on the RCAs.
If you made sure to use the proper switch setting on the DSR1 and the proper input connectors on the amps then you need to split the signal path at the T harness to look upstream to the radio (check that you have signal on the RCA radio outputs using an o-scope or MM). To test downstream through the DSP/amps (or amps alone) I like to use a test-tone generator like this one.
SCORPION111674
Audio Systems
Feb 17, 2022 09:11 AM
Gilles Godin
Audio Systems
Jul 2, 2020 04:50 PM
Roadie13
Audio Systems
26
Jan 20, 2018 10:25 AM
gcroach
Audio Systems
Feb 13, 2016 08:35 AM
UltraNutZ
Audio Systems
17
Sep 13, 2013 09:45 AM
