Cvo sound system
Old Jun 22, 2020 | 12:21 PM
Gilles Godin's Avatar
Gilles Godin
Stage I
Default Cvo sound system
I recently received the 4 speakers, 2 amps & wiring off a Stock 2018 CVO. Attempted to swap them with my 2017 Ultra Limited. Paid over $1000. for installation by the HD dealership to do the job. When I picked the bike up, the tech installed only one amp. Said it would require the Stage 2 speakers not the 75w speakers I had that came off the CVO. confused - The 2 Amps & speakers I had that came off the CVO. Wouldn’t they have been connected on the CVO? Why would they only connect one amp and not both? I was from the understanding that each pair of speakers required one amp. Can someone shed some light on this as it just doesn’t make sense. Also the speakers had very little improvement when done. Waste of money.
Old Jun 22, 2020 | 12:53 PM
mrmagloo's Avatar
mrmagloo
Total waste of money. Imho, I'd do everything you could to try to return the stuff and get your money back. With a $1,000, you can put together a enormously better system.
Old Jun 22, 2020 | 12:57 PM
JimTJr's Avatar
JimTJr
Sad face, ( wish you'd have came here first before you bought it...
Old Jun 22, 2020 | 03:35 PM
boosted20v's Avatar
boosted20v
You are correct. each pair of speakers require an amp. The CVO speakers are the stage II. Tech clearly didn't know what he was doing for $1000 I'd make them fix it!
Old Jun 29, 2020 | 07:02 PM
rlager's Avatar
rlager
Doesn't make sense to me either - but then i did a little reading. It appears that the speakers on the stock 2018 CVO limited are Stage I, not Stage II. You can tell as the Stage I speakers have a single speaker connection, while Stage II speakers have a dual connection (bi-amped). If you have two amps - you could conceivably pick up some Stage II speakers and make it work (the amps themselves are not different although they may try to tell you they are. Stage I, Stage II - it's all the same amp), but after 5 years going down the Boom Stage II road with H-D, I'd listen to these guys . On the Street Glide CVO - those are Stage II speakers, which I don't understand why Harley would cheap out on the CVO Ultra but whatever.
Ultimately the folks you took your bike to should have evaluated the parts you brought in and told you up front what the deal was before you spent a dime.
Old Jul 1, 2020 | 05:43 PM
8track's Avatar
8track
Default Don't bother
Don't bother trying to make them fix it, it's not worth it. Even properly installed you will never be happy with that system. But if you do keep that system start stockpiling speakers because they definitely don't last and there are few, if any, acceptable aftermarket options. Good news is you can find people that will give you factory speakers for the cost of shipping.
Old Jul 2, 2020 | 10:48 AM
boosted20v's Avatar
boosted20v
Didn't pick up on the fact that you had a limited. Non Limited CVO's have the Stage II's.
Old Jul 2, 2020 | 04:50 PM
8track's Avatar
8track
The 2015 CVO Limited came stock with one amp and 4 speaker Boom system. I believe 2015 is the only year with one amp.
luc.who
Touring Parts
Apr 18, 2020 09:00 AM
amrodrigues
Audio Systems
Sep 12, 2018 04:51 PM
RinTin
Screamin Eagle CVO Models
14
Sep 7, 2017 08:07 PM
robertg
Jan 22, 2017 07:37 PM
kwrench61
Jan 10, 2016 07:49 AM
