help with noise
Old May 17, 2022 | 03:14 PM
converted1's Avatar
converted1
Default help with noise
i have a 2020 trike with
2 motog2 fairing
2 prv lower fairing
2 diamond ms pro 65 tour pak
stinger 700/4 amp
this hissing noise did"nt start until i got it flashed with the 8 spkr/2 amp flash
looking for info to get rid of this noise
TIA
Old May 17, 2022 | 03:44 PM
golfblues's Avatar
golfblues
You need to readjust your gains
Old May 17, 2022 | 03:55 PM
converted1's Avatar
converted1
its the amp gains you talking about right
Old May 17, 2022 | 04:02 PM
teedoff65's Avatar
teedoff65
Yup. If you set them before the flash, you'll need to set them again
Old May 17, 2022 | 04:15 PM
converted1's Avatar
converted1
will be doing that first thing in the morning
Old May 17, 2022 | 05:28 PM
golfblues's Avatar
golfblues
Exactly.....know your target voltage and dial them in. I would guess 22.4 volts for 125watts x4 at 4ohm. 1k -5db test tone
Old May 17, 2022 | 09:22 PM
converted1's Avatar
converted1
i use the dd1 test set
Old May 18, 2022 | 11:53 AM
cshocker's Avatar
cshocker
That's a great tool. I suggest also checking voltage after using, to see where you're at. Not every tool is 100% accurate.
Briguy1
Audio Systems
Oct 7, 2021 06:08 PM
Roadking69
Audio Systems
May 27, 2021 02:25 PM
coolbikeguy
Audio Systems
Aug 25, 2020 08:30 AM
KJBennett
2014-2024 Touring Models
Jul 13, 2014 10:56 PM
willett58
Aug 18, 2007 12:10 PM
