Does anyone know which 2 channels of the RCA inputs to use to bridge a Soundigital 800.4 evox2? I’ve searched all over the web and can’t find the answer. Thank you
What?!? You use all 4. Your speakers are bridged, not the rca cables. If you only have 2 cables, buy splitters.
I’m well aware of the of speaker wire configuration for bridging, but most of the traditional amplifiers I’ve ever used you only needed to use 2 channels of the RCA inputs when bridging a 4 channel. It looks like I’m buying splitters. Thank you
Never heard of bridging the inputs! What does that get you? Bridging the output's get's you double the watts or splitting the outputs gets you an extra channel.
I have never seen a 4 channel amp being bridged with only 2 inputs. If your only wanting to use 2 channels out then its 1/2 and 3/4. It shows you on the speakers output side what channels you can bridge. Never saw a 4 channel bridged with all channels without splitters. You wont get signal to all channels without using all 4 inputs
