They def copied the technology from other manufacturers. Plus the battery is only 20ah. So not as good as a legit lithium battery maker. People will need the BMS for this battery.
There isn't that many companies that make the actual lithium cells but they can have quite varying specs and qualities. The manufacturing process can produce high and low quality cells. The problem is it is very hard to know which ones you are getting! As a general rule the heavy cells produce the best power.
It is then down to others to assemble them into complete motorcycle batteries.
If any maker of a motorcycle battery has not put in a BMS do not touch it with a barge pole.
