Upgrade! Adding speakers, amp suggestions. Rabbit Hole!
Old Sep 7, 2022 | 05:35 PM
dhollywood's Avatar
dhollywood
Originally Posted by cshocker
You would need a 2ohm version of the 2400 to bridge the 200L. Then you’ll get less power to neos. And you’ll get the same power to 200L from 1200.2 as the 2400
can the GZ’s handle 300 watts?
Old Sep 8, 2022 | 09:11 AM
cshocker's Avatar
cshocker
Yes, but........ You have to cross them higher and tune more. I like them around 200-225, crossed at 125hz. And I like them to last.
Like I said, the 2400 will be a bit overkill, but you don't need to use all the power available. And the amp will be happier
Old Sep 8, 2022 | 09:27 AM
dhollywood's Avatar
dhollywood
ok, thanks.. I saw in another post that you installed cicada 8’s in your lowers, at one point. Have you had the opportunity to hear the Cicada CM65 6.5 Midbass in fairing and/or lowers?
Old Sep 8, 2022 | 09:52 AM
cshocker's Avatar
cshocker
I have not heard the CM's. I've heard the CH 6.5's in fairing and lowers. They are loud and clear
Old Sep 8, 2022 | 12:38 PM
dhollywood's Avatar
dhollywood
got ya.
Briguy1
Audio Systems
Aug 30, 2020 03:44 PM
Briguy1
Audio Systems
Jul 28, 2020 10:03 PM
Bflo_SG
Audio Systems
Aug 6, 2019 08:52 AM
dunskit
Audio Systems
Mar 17, 2019 07:28 PM
davessworks
May 31, 2010 11:17 AM
