Amp Connection
Old Oct 11, 2022 | 04:13 PM
HD22's Avatar
HD22
2nd Gear
Default Amp Connection
I have a question for my installation.
-Harley Davidson Street Glide with Boom GTS 2019
-The radio has been flashed
-2 Fairing Speakers Ground Zero 6,5 Coaxial
-OFC power & ground cables and Speaker wires
I just bought SD amp 400.4
I will bridged the amp for 2 x 200rms
My questions is about the High level input connections
Can I only use only the front output radio speakers wire like I note on this plan ?
any other advise ?
Thanks
Ben
Old Oct 14, 2022 | 04:11 PM
smittyrock3's Avatar
smittyrock3
I have the same amp and a GTS head unit but I used line levelers so I have RCA inputs. Typically you need inputs for all four channels to run a 4 channel amp with two bridged output channels. I've never done it (so I can't say it won't harm anything) but you may be able to run the left channel to say channel 1 and 3 and right to 2 and 4.or vice versa. When you got the head unit flashed did you ask them to activate the rear channels on the radio? If that was an option for 2019s I have a 2020 and just used RCA Y adapters.
Old Oct 16, 2022 | 04:35 AM
decencyxdefied's Avatar
decencyxdefied
Delete
Old Oct 16, 2022 | 01:38 PM
Dsm Limited's Avatar
Dsm Limited
The easy answer is a PAC Line out converter that’s been setup with plugs that will connect to your front speaker plugs. From there RCA splitters to connect from LOC to the amp. All 4 inputs need filled for bridging that amp
Old Oct 20, 2022 | 12:02 PM
sponger's Avatar
sponger
https://www.702motoringlasvegas.com/...amp-connection
Old Oct 21, 2022 | 04:40 PM
crackalack's Avatar
crackalack
please let me know where you found those items in Canada. thats exactly the setup i want to run, connected that exact way
pan63125
Audio Systems
Nov 8, 2021 11:52 AM
Timothy Rau
Audio Systems
Aug 26, 2019 02:05 PM
silverback17
Audio Systems
Jul 11, 2017 05:23 PM
gpp
Sep 18, 2008 06:11 PM
MattMeaz
May 23, 2007 03:30 PM
