Tweeter size
Old Jan 29, 2023 | 05:10 PM
kloccwork419's Avatar
kloccwork419
Default Tweeter size
Anyone know of a good tweeter that has the same cutout and thread size of a hertz st35? Looking for something else before I just buy another set of hertz. I have custom billet grills that screw on the st35 but one of the tweeters broke. The design of the screw on connector is terrible inside the speaker. Tighten them too much they rip the foil thin connections inside. The new neo ones use a plug probably because of this if I had to guess
Old Jan 29, 2023 | 09:50 PM
Babyboy's Avatar
Babyboy
Re solder the lead back on to the terminal.
I have rebuilt/repaired many of those horns.
There is a rebuild kit you can get thru your local hertz dealer for about $40 each.
Old Jan 30, 2023 | 07:29 AM
kloccwork419
Talking about the voice coil replacement? I have repaired it once. Maybe Ill try it again. Just pisses me off. The problem is the plastic spacer that wants to turn when you tighten it, then it just pulls the connection apart. Wonder If i could beefin it up some. I want the neo but theres no way I would drop that much money for a tweeter
Old Jan 30, 2023 | 06:45 PM
Rcloud72's Avatar
Rcloud72
if you’re going to buy a new set check out the diamond audio m075t. I really like mine. Not sure if they’ll fit ik the same size hole in the grill as the st35s. But I’m sure diamond has one that’ll fit the hole you have. I love the sound quality of the diamond. I love the hertz as much or more tho tbh. I bought the diamond bc they’re shallow mount
LouK
General Topics/Tech Tips
Sep 19, 2021 05:15 PM
ozzy49938
Feb 21, 2017 09:20 AM
Springerfan
Audio Systems
Feb 12, 2017 03:43 AM
airfuel
2014-2024 Touring Models
Aug 9, 2014 01:20 PM
kitehog
Audio Systems
Sep 20, 2013 02:28 PM
