Sd 800.4 evosp capabilities
Old Apr 25, 2023 | 01:20 PM
prostreet124's Avatar
prostreet124
Default Sd 800.4 evosp capabilities
I have a 2018 RG I'm give a little boost to, PRV500-NDY-4's in the fairing lowers and thinking GZ yellow baskets in the fairing, already have new PRV's and new 700.4 Stinger amp but seeing many opinions that's not enough power for the Yellow baskets, would the SD 800.4 evosp be enough? I know there's similar an output level, but...
Old Apr 25, 2023 | 01:32 PM
cshocker's Avatar
cshocker
So you want to run 1 or 2 amps?
You wouldn't be gaining much going from Stinger to SD800.4.
You have a few options?
1: install a LEX amp rack and run 2 amps
2: Run just a SD 1200.4
3: Run 2 sets of GZ coax off a SD 1000.1, 1 ohm (my recommendation).
Old Apr 25, 2023 | 05:21 PM
prostreet124
How would they be wired with the 1000.1 1ohm ?
Old Apr 25, 2023 | 06:22 PM
cshocker's Avatar
cshocker
All positives together and all negatives together. It’ll be in mono.
I did same setup except with a Euphoria 1k in a Road Glide. It pounded pretty good for 4 speakers and 1 amp.
Old Apr 27, 2023 | 04:05 PM
mrmagloo's Avatar
mrmagloo
I know alot of guys swear ( or is it sware? ) by mono, but I dunno. Yeah on the slab you probably cannot tell, but I'm pretty sure around town it would be pretty obvious and would drive an **** old ***** like me crazy.
I'm running the SD 1200.4 2-Ohm and it's a beast. I like it alot.
Weeboy1
Audio Systems
23
Apr 2, 2022 10:49 PM
RGpittsburgh
2018+ Softail Models
23
Nov 28, 2021 04:58 PM
Highway80
Audio Systems
Jun 9, 2020 04:13 AM
Weeboy1
Audio Systems
Aug 16, 2018 08:55 PM
05hdultra
Audio Systems
44
Jun 3, 2014 08:10 PM
