Adding a Sub to a Saddlebag
Old May 22, 2023 | 08:56 PM
NorthWestern's Avatar
NorthWestern
Default Adding a Sub to a Saddlebag
I have been reading, and reading several threads here in the Audio Subforum, but could not come up with a clear solution.
I have my fairing system installed, and of course it is wanting in the area of bass and "warmth". I clearly could do better on the tuning of my Rockford DSP, but even if I get it as good as possible...you know.
I have a few subs in the garage, all 2 ohm: 8" JL, 10" RE, 10" RF and I have a JL 500w mono class D that I can fit in the fairing. I say this, because you guys are magic, and I know you have all done a 2nd amp, and had the damn fairing fit back on , SOMEHOW
What is the best way to install the sub in the bag? This is the question I am having trouble with. I have seen threads like this https://www.hdforums.com/forum/milwa...and-after.html but that install looks a bit sketch.
TLDR:
Is there a mounting bracket available, or kit to CLEANLY install a 8 or 10 inch sub in a saddlebag that you gurus would recommend?
Old May 23, 2023 | 05:55 AM
Babyboy's Avatar
Babyboy
For starters you will need to figure out which speaker will work best in the air space available.
Then you have to decide if you will be using a sealed or ported enclosure for the frequency range you want the speaker to play.
Adding speakers inside the saddle bags requires more than just mounting a speaker and hooking it up to get the best performance from the labor and money invested.
A low powered sub will be lost as the bike is started and/or over 20 mph.
Nagy Customs has the best selection of mounting rings for the saddle bags.
Old May 23, 2023 | 08:22 AM
NorthWestern
Copy. Thanks, I will get to work, and read up more on what you have told me here.
Old May 23, 2023 | 08:34 AM
Babyboy's Avatar
Babyboy
Remember to take into consideration the air space the speakers,rings and ports will take away from the total airspace.
Old May 23, 2023 | 08:44 AM
FLASH1970's Avatar
FLASH1970
TLDR:
i designed in CAD and 3D printed my own amp rack to fit 2 sound digital EVO X2 800.4's in my fairing... might tweak the design to work with other amp combos as well. working on a DSP bracket now.
I went with the Nagy rear sub rings for 8's. i think it turned out pretty well for being a newb. when i cut the second ring, it turned out better than the first because i learned from mistakes i made on the first one. theres a couple youtube videos on installing sub rings. they have mid bass driver rings and sub rings so just make sure you get the correct ring. i might end up sealing my bags and/or fiberglassing them or putting in mid bass drivers if i dont like how it sounds. kind of a trial and error type thing.
darkcustom7
Audio Systems
Mar 17, 2018 01:23 AM
uwiik
Audio Systems
Mar 18, 2014 04:56 PM
BPD101
General Topics/Tech Tips
Mar 8, 2013 10:24 PM
foxman
Mar 23, 2010 07:35 PM
profinish
Dec 8, 2007 09:03 PM
