2Ohm vs 4Ohm
Old Sep 3, 2024 | 02:29 AM
Glenn Gorman's Avatar
Glenn Gorman
Default 2Ohm vs 4Ohm
Just curious, but are there any differences between 2Ohm vs 4Ohm speakers, besides power?
Old Sep 3, 2024 | 06:26 AM
timbo141's Avatar
timbo141
Resistance, best to match your speaker to your Amp rating. High quality 4 ohm amps will say 2 ohm stable.
There is a possibility of burning out a 4 ohm amp with 2 ohm speakers.
Old Sep 3, 2024 | 07:25 AM
teedoff65's Avatar
teedoff65
There's a sticky explaining all that and more. Some way beyond my brain to comprehend. lol But good info to read and refer back to.
Old Sep 3, 2024 | 11:25 AM
07UltraGuy's Avatar
07UltraGuy
For the sake of simplicity, look at it this way.
8 Ohm & 4 Ohm speakers are most common. H-D uses a 2 Ohm variety.
If you connect 4 Ohm speakers in place of your factory 2 Ohm speakers (and no other changes), you will get 50% of the output volume with the same settings on the gear.
If you were to replace your factory 2 Ohm speakers w/ 8 Ohm speakers (and no other changes) you would get 25% of the output volume with the same settings on the gear.
This is how/why just buying a nice pair of typical speakers isn't enough of an upgrade to an HD audio system... it will require an amp and/or head unit swap as well.
Conversely, if you replace 8 Ohm speakers with ones that have either 4 Ohm or 2 Ohm (and no other changes), the output volume will increase by the same factor as above.
Old Sep 4, 2024 | 04:02 AM
Glenn Gorman
I've read that sticky. So then as I understand it, there is no sound quality difference between using 2Ohm or 4Ohm speakers. It's just a power/resistance thing. Less resistance equals more power going to the speaker, but not better sound quality.
Old Sep 4, 2024 | 04:55 AM
Dsm Limited's Avatar
Dsm Limited
That is correct.
Old Sep 4, 2024 | 05:13 AM
DeeRoe's Avatar
DeeRoe
Old Sep 4, 2024 | 03:58 PM
golfblues's Avatar
golfblues
I put 2ohm 6x9s in my bags and it makes a huge difference. I can finally hear them at 75 plus...
wjl24
Jan 8, 2017 12:57 PM
ridedaddy
Audio Systems
Sep 15, 2013 10:46 PM
pit1600
Jan 17, 2012 07:50 AM
FFHD05
Jul 20, 2011 08:57 PM
Pavetack
Audio Systems
Jun 7, 2011 03:37 PM
