Amp turn off/on functionality with GTS head unit
Old Oct 25, 2024 | 09:35 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Default Amp turn off/on functionality with GTS head unit
Howdy all,
I'm starting to reintegrate audio equipment slowly in my new 2023 Ultra Limited. Right now I've got the Cicada T harness going into an Arc PSM DSP and then to my amp. I have had the Rockford flash done on the head unit.
The Cicada instructions mentioned tapping a TR-4 low voltage trigger module on one of the speaker outputs like I did on my pre-Rushmore bike to act as a remote turn on for the audio equipment. The thing is even after having the Rockford flash done it keeps the TR-4 energized constantly even when the head unit is off. I would like to be able to shut the equipment down by turning the head unit off if possible. Has anyone gotten this to work with a GTS head unit?
Old Oct 25, 2024 | 09:57 AM
lefty33's Avatar
lefty33
Originally Posted by Hoyt 1911A1
Howdy all,
Morning Hoyt! When I had my system, I used this one from V-Twin Audio. Easy install as it plugs inline.
Old Oct 25, 2024 | 10:18 AM
Hoyt 1911A1
Morning Hoss,
I think I am using that same plug to get the turn on functionality at the moment. My wish is for everything to turn off when I turn the head unit off. Right now when I turn off the head unit the DSP and amp remain powred on. It's not too bad now, but when I get the rest of my old system installed that would be a lot of equipment live all the time when the ignition switch is turned on. This bike will kill the battery quick just with the factory loadout.
Bigm1717
Audio Systems
Jul 27, 2022 12:50 PM
GunslingersNation1
Audio Systems
Jun 24, 2020 10:39 AM
Stew_FL
Audio Systems
May 23, 2018 05:30 AM
Briguy1
Audio Systems
Nov 18, 2017 10:15 PM
roussfam
Aug 25, 2013 02:12 PM
