Speaker Pods
Old May 14, 2025 | 08:18 PM
Mondal99's Avatar
Mondal99
5th Gear
Default Speaker Pods
Hello,
I have a 2014 Street Glide Special. I picked up a slightly used tour pack with speaker pods and a few other miscellaneous items. I took everything off and had the tour pack painted. Now I am putting it back together.
1. I want to replace the weather proof gasket material that goes between the tour pack and the actual speaker pods. Any suggestions? Could I get something from the hardware store that would work just as well?
2. My bike has never had the rear speakers or tour pack. Do I need to go to HD and have them update anything so the rear speakers will work as they should?
Thanks in advance for any advice.
Old May 15, 2025 | 07:48 AM
Babyboy's Avatar
Babyboy
Originally Posted by Mondal99
Hello,
Being you have a SG. you will need to have the headunit flashed unless you are installing an aftermarket HU.
Are you installing an amp and aftermarket equipment for the audio ?
TP PODS gaskets you may find neoprene material at the local hardware store and cut to fit or use silicone in between.
BTW what part of Illinois are you in? There may be a memebers in your area to help you if needed and possibly flash your stock headunit.
Old May 15, 2025 | 05:33 PM
Mondal99's Avatar
Mondal99
5th Gear
Originally Posted by Babyboy
Being you have a SG. you will need to have the headunit flashed unless you are installing an aftermarket HU. - It is the original headhunt. (audio boom)
Are you installing an amp and aftermarket equipment for the audio ? - no amp or aftermarket equipment
TP PODS gaskets you may find neoprene material at the local hardware store and cut to fit or use silicone in between. - This stuff is 1/8 inch thick, do you think this would work? https://www.amazon.com/dp/B09TXG4R6V...sin_title&th=1
BTW what part of Illinois are you in? There may be a memebers in your area to help you if needed and possibly flash your stock headunit. - I am in Joliet
Thanks for the fast response......that would be great if anybody near by could flash my stock headhunt
Old May 15, 2025 | 06:49 PM
Babyboy's Avatar
Babyboy
Mondal99
You don't have very far to go to a fellow forum member if you are in Joliet. I am just north of you in Lockport.
Sent me a text at 815-905-1524 when you get this and let me know who you are. I will respond
Ruko
May 1, 2022 09:57 AM
UrbanRunner
May 2, 2020 06:33 AM
liljoea2002
Audio Systems
Apr 15, 2019 08:14 PM
zproud
Audio Systems
Nov 16, 2014 08:50 AM
