FLHTP Audio Question?
Old Jan 21, 2026 | 09:03 AM
Babyboy's Avatar
Babyboy
Originally Posted by Sullyxlh
Swapped out the hand controls on mine and it didn't require any BCM flashing they worked straight out of the box
I do use the Idatalink Maestro MRR2 interface but don't know if that has anything to do with not having to flash it tho..
The Idatalink module programed the canbus system for the hand controls which would eliminate the need to program the BCM.
Old Jan 28, 2026 | 01:00 PM
gerby151's Avatar
gerby151
You could just add the Cicada amp with built in Bluetooth and add Mmats of Cicada speakers to the fairing and roll. I know the amp would be more than you would need for the Mmats but would give you room to expand
Buy 175 W X 4CH DSP PRO AMPLIFIER - Cicada Audio
Buy 6.5-INCH PRO COAXIAL SPEAKERS - 4Ω - Cicada Audio
Pro Audio Car Speaker MMATS PA601 Mid/Bass 6.5" Driver
Old Mar 29, 2026 | 09:36 AM
FatboyCrimson's Avatar
FatboyCrimson
Another FLHTP owner here, much like the original poster (sorry do not mean to highjack the tread) I have thought about adding a sound system to my Cop bike. however, its between 2250 to over 3k for decent setup from Volunteer audio! I'm interested in that Cicadia set you posted. what else is needed to install, harness etc.? What's the difference between the two speakers in the links?
Old Mar 30, 2026 | 01:53 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
A buddy of mine just got a used GT head unit dirt cheap and plugged it up with a set of speakers to get by. I think you may have to swap out the left controls though to get volume to work. Hopefully someone that has gone the used Harley head unit route can confirm.
If you want to use headsets though the other guys have some good tips.
masterofyard
Audio Systems
Jun 25, 2020 01:56 PM
Qalen
Audio Systems
Dec 18, 2018 01:20 PM
uplandpinter
Audio Systems
Jan 21, 2017 09:40 PM
TimHixson
Audio Systems
Jul 26, 2013 06:00 AM
biggrantwilliam
Jun 19, 2008 08:06 PM
