j&m amp problems
Old May 17, 2012 | 11:51 AM
dartpro1's Avatar
dartpro1
Default j&m amp problems
2011 flhx I have the 500 watt amp. Going down the road the sound just stopped and comes and goes.. The right speaker sounds like its bad. The light on the amp is flashing red so I unplugged the amp from the front speaks and left the rear bag lid speakers hooked up... Now the light on the amp is green and works just fine... So why is it shutting down when hooked up with the bad speaker? The speakers are the j&m rokkers...
Old May 18, 2012 | 06:37 AM
UltraNutZ's Avatar
UltraNutZ
because the voice coil on the speaker is shorted out. This creates a direct short between positive and negative posts on the speaker itself. When the coil heats up, it shorts, when it cools down it opens back up hence the reason your amp is cutting out when that speaker is connected. Call J&M and they'll take care of you.
Old May 18, 2012 | 09:13 AM
kccode1's Avatar
kccode1
Yep most likely you have a short on that speaker. I haven't seen the actual coil short out as the wire is very thin, but it is possible. I would also look at the wire to that speaker as it may be pinched. You may be shorted to a ground somewhere and that could happen the speaker too.
I would first swap speakers to see if the speaker is bad.
shaneballance
Audio Systems
15
Aug 13, 2018 03:51 PM
Eshaw301
Audio Systems
Dec 29, 2014 11:22 AM
Fozzy4325
Audio Systems
22
May 8, 2014 05:01 PM
customsoftail200
Dec 12, 2011 10:24 AM
Roadie09
Jul 13, 2009 04:40 PM
