yes - is it a HD amp or aftermarket amp? If aftermarket, this is the error you'll get so ignore it. However you still need to check the amp and wiring.
If HD amp, then you need to have the amp and wiring checked.
no - check connections on back of radio. make sure plug is properly seated.
swap speaker with front right and see what happens
Hello, we were recently riding and the sound dropped low and now will not turn up loud again. These codes showed up for the radio B1338c, B1346c, B136Ah. When I look up these codes it says open front speakers... how do I fix this!?!
