the object of the game is to match components so yes in theory. However with that said, I think in your case I would be more concerned about future upgrades because once you get a taste of that 24w amp, you'll want more. Kill 2 birds with 1 stone... get better speakers now and not have to worry about upgrading them later when you decide to change amps.
I got the speakers and the rings. My tweeter actually touches the grill cover. Is this a problem? I can see the grills getting wet and trapping moisture against the tweeter.
What speakers did you get? With the adapter rings, no speaker (unless it has some very large protruding tweeter) should touch the stock grill cloth as they are set back away from the grill in their mounting.
hmm.. that's weird. those speakers shouldn't be anywhere near those grills.
So you put the stock grill on the frt of the adapter, secured the adapter to the inner fairing essentially "sandwiching" the grill between the adapter ring and inner fairing, then attached the speakers to the back side of the adapter ring?
those grills (if they're stock) are made from acoutical water resistant materials. Where did you get the adapter rings?
He may have bought them from Throttle Up Industries, thats where I got my adapter rings from. I think they might be a little more shallow than some of the other rings......Mine actually do the same thing, The tweeters do "slightly" touch the grills. It doesn't bother me at all... You really can't tell just lookng at them , but if you touch the grille you can "slightly" feel the tweeter cover. No big deal, I want want the speakers as close to me as possible anyway. Also I see he has an RG ..Mines an SG. Here are some pics
