Need Hogtunes info please
Old Dec 13, 2012 | 01:40 PM
UltraNutZ's Avatar
UltraNutZ
interesting.. Where'd ya get the PA emblem? pealed it off one of the speaker grills? looks cool...
Old Dec 13, 2012 | 02:44 PM
SGLarry's Avatar
SGLarry
Thanks, I cut them off of the Polk grilles, trimed 'em down on my disk grinder, then finished them up with a rubber wheel in a hand piece. Cut a couple of small pieces if 3M emblem tape anfd stuck 'em on the grilles...I've got OCD....
Old Dec 13, 2012 | 06:10 PM
HD32141's Avatar
HD32141
Originally Posted by UltraNutZ
those grills (if they're stock) are made from acoutical water resistant materials. Where did you get the adapter rings?
Local, and I got another set this afternoon. Everything is in.
I have one wiring question- the crossover leads have no connectors on them. The Polk manual shows the traced wire going to + and the plain wire going to - on the amp.
The amp has connectors on the wires to go to speakers, or now to the crossover leads. The HT manual says connect color to color, etc, "they will only go on one way". This doesn't tell me what is + and - for my crossover leads.
Which is which? I have brown/black on the clutch side and blue/black on the brake side to connect to the crossovers. Common sense tells me black is negative but when I unhooked the factory speakers, yellow was to positive. But the yellow wire will only connect to the black wire from the amp.
Go figure.
Old Dec 13, 2012 | 06:14 PM
HD32141's Avatar
HD32141
One more thing- the brown/black and blue/black wires have female connectors. The black wires have smaller female connectors than the blue and black.
Is this a hint?
Old Dec 13, 2012 | 06:20 PM
UltraNutZ's Avatar
UltraNutZ
hmm.. i'm lost.. where are you getting these colors from? On the stock speakers, the right front wires are
Light Green/Black +
Gray/Red -
left front wires are
White/Orange +
Light Green/White -
Old Dec 13, 2012 | 07:06 PM
HD32141's Avatar
HD32141
Factory speaker wires-
Clutch side-
Green/yellow to HT yellow wire
White/orange to HT black wire
Brake side-
Green/black to HT green wire
Gray/red to HT black wire
These are going TO the amp.
This leaves the speaker OUT wires from the amp which are:
Clutch side- brown/black
Brake side- blue/black
They connect to the cross over. The cross over has tinned wire ends (no connectors).
The speaker end of the crossover will only connect one way so I hooked them to the speakers.
The tinned cross over ends have to go to the brown/black and blue/black.
Right?
If yes, does the traced wire go to black or brown/blue?
The Polk manual says the traced wire goes to +. Is black positive (see earlier concern on this) or is the brown/blue wire +?
Old Dec 13, 2012 | 07:10 PM
HD32141's Avatar
HD32141
Still lost? I'm getting a headache.
Old Dec 13, 2012 | 07:22 PM
UltraNutZ's Avatar
UltraNutZ
ah.. ok.. gotcha now...
the black wires with white stripes are +
brown and black are your left (clutch side) speakers wires. Brown being +
Blue and black are your righ (brake side) speaker wires. Blue being +
Old Dec 14, 2012 | 05:48 AM
HD32141's Avatar
HD32141
THAT'S what I thought but...
as I said, common sense tells me black is negative but when I unhooked the factory speakers, white/orange and gray/red was going to positive on the speakers. But the white/orange and gray/red will only connect to the black wire from the amp.
Seems like + and - reversed. This is what's screwing with my head.
Old Dec 14, 2012 | 06:04 AM
HD32141's Avatar
HD32141
Just to spell it out once more...
Clutch side-
Green/yellow (was to speaker-) now goes to HT yellow wire
White/orange (was to speaker +) now goes to HT black wire
Brake side-
Green/black (was to speaker -)( now goes to HT green wire
Gray/red (was to speaker +) now goes to HT black wire
These are going TO the amp and they have male/female connectors and this is the only way they fit.
They normally would connect to speakers but now will connect to the crossover leads of my Polk MM651 speakers which are connected to the speakers. The crossover lead has tinned wire ends (no connectors).
The Polk manual says the traced crossover wire wire goes to +. Is black positive or is the brown/blue wire + on the speaker OUT from the amp?
Common sense says black is negative but when I unhooked the factory speakers, white/orange and gray/red was going to positive on the speakers. But the white/orange and gray/red will only connect to the black wire from the amp.
This is what's screwing with my head… seems like + and – have reversed.
