Harmon/Kardon Software Upgrade
Old Mar 7, 2013 | 07:50 AM
Zohan's Avatar
Zohan
4th Gear
Cool Harmon/Kardon Software Upgrade
Following directions to upgrade the radio software for my 2006 Ultra per HD website. Downloaded zip file and extracted the two files. How do I save these two files in a "standard format", "iTunes", or MP3?
One file is is a "upg", the other is a "bin" file.
Suggestions?
Old Mar 7, 2013 | 08:01 AM
UltraNutZ's Avatar
UltraNutZ
you have to burn those files to a CD then drop the CD in the headunit.
Old Mar 7, 2013 | 08:03 AM
NJShoreScott's Avatar
NJShoreScott
Zohan,
You do not need to save them in a standard format. They are already in the correct format for the radio. What the instructions say is to BURN them to CD in a Standard Format (HFS Plus/ISO 9660). That essentially says that what ever software you use to burn the files to the CD has to support one of those 2 standards. It does NOT change the file types or anything, it is just the way they get burned.
You might want to refer to https://www.hdforums.com/forum/touri...e-upgrade.html for some more detail on the instructions.
Old Mar 7, 2013 | 08:06 AM
UltraNutZ's Avatar
UltraNutZ
also you want to burn/record at 16x speed and/or below. Any higher and my experience as well as others is it's hit and miss as to whether the headunit will read the CD.
Old Mar 7, 2013 | 10:21 AM
Zohan's Avatar
Zohan
4th Gear
followed instructions, never got past "Verifying Image" on the display...used 4x speed and CDR-W?
Old Mar 7, 2013 | 10:25 AM
UltraNutZ's Avatar
UltraNutZ
Cdrw is fine as long as you close session. Better to use cdr
Old Mar 7, 2013 | 10:27 AM
Zohan's Avatar
Zohan
4th Gear
Default Thanks
Maybe bad disk...will try new one later today.
Old Mar 7, 2013 | 06:07 PM
Zohan's Avatar
Zohan
4th Gear
Unhappy
Bought new Sony CD-Rs and burned using Windows XP. After I insert disk, no other message than "Verifying DSP Image" shows. Followed directions and even made sure speed was correct and still software will not upgrade.
Old Mar 7, 2013 | 06:10 PM
NJShoreScott
Zohan, I had a similar issue when I did this a while back. I burned the CD with a different piece of software, and that fixed it for me. Try switching your burner software and see if that helps.
Old Mar 7, 2013 | 06:15 PM
UltraNutZ's Avatar
UltraNutZ
this is an old thread but check it out.
https://www.hdforums.com/forum/touri...cd-player.html
