Installing help for Sony DSX-S310BTX
Old Mar 19, 2013 | 03:05 PM
1sweetglide08's Avatar
1sweetglide08
Originally Posted by Raxus
Got it from OHS Powersports seller on Amazon. BT said it would refund me the adaptor, but I think the color wires match...so wouldn't it be just as easy to splice into the adaptor?
I would contact Biketronics and see if they would trade your module with one that has the plug for your adapter. This way there will be no cutting and splicing wires, Just plug and play.
Old Mar 19, 2013 | 04:30 PM
Raxus's Avatar
Raxus
Already soldered and spliced so hopefully it works.
Old Mar 19, 2013 | 04:55 PM
UltraNutZ's Avatar
UltraNutZ
adapt and overcome! love it!
Old Mar 19, 2013 | 05:01 PM
Raxus's Avatar
Raxus
Am I suppose to slice into this? If so, do I leave the connector on?
https://www.facebook.com/photo.php?f...type=1&theater
Old Mar 19, 2013 | 07:55 PM
UltraNutZ's Avatar
UltraNutZ
if you're running rear speakers off the amp you have 2 choices.
1.) splice into pins 1,2,24,25 for your rear speaker wires and yes you want to leave the connector on
2.) leave the connector alone altogether and simply run 2 pair of speaker wires to the rear tour pak pods.
Old Mar 19, 2013 | 08:24 PM
Raxus's Avatar
Raxus
I assume I want the rears amplified so yes.
Gonna stop for the night but think we made some nice progress. Got all the medallion gauges installed and working (including the oil temp sensor). Front speakers on, tho not wired. last but not least the driving lights, tho not hot wired yet. here's a nice lil pic
Rax
Old Mar 20, 2013 | 03:49 AM
UltraNutZ's Avatar
UltraNutZ
looks nice sir. With all that work you've done, the amp will be nothing to install.
Old Mar 20, 2013 | 05:01 AM
Raxus's Avatar
Raxus
Yeah..right...losing sleep over it actually. No joke...
Old Mar 20, 2013 | 06:27 AM
UltraNutZ's Avatar
UltraNutZ
no worries, it's easier than you're making it out to be. :-)
Old Mar 20, 2013 | 08:01 PM
Raxus's Avatar
Raxus
Hopefully I am reading this doc right. To wire the crossover to the speaker take the female ends and connect to the polk speaker? That leaves a positive and negative spliced wire that I assume connects to the old speaker wire?
I would be talking the basic setup in the diagram:
