need advice on amp
Old Mar 22, 2013 | 03:56 PM
big papa59's Avatar
big papa59
Stage III
Default need advice on amp
I have Fusion ms-ip600 and polk mm691 in my reckless fairing. I want to add a amp and later add another set of mm's in my saddlebag lids.Which amp should i use?
Old Mar 22, 2013 | 04:17 PM
UltraNutZ's Avatar
UltraNutZ
my understanding is the JL Audio XD400/4 fits perfectly inside that reckless fairing so that's a good choice to go with. You also have the Soundstream PN4.520D as a good choice.
Looking at the wiring diagram for the ms-ip600 it shows that you have 2 sets of speaker level (high level) outputs (front and rear, right and left) and 1 set of RCA (low level outputs) right and left. Either amp you choose you can run the high level outputs to the amp inputs and maintain fader control, or you can run RCAs and Y adapters to the amp low level inputs but you won't have fader control.
Budda109
Audio Systems
Apr 15, 2024 11:46 PM
Baggergee
Audio Systems
11
Mar 18, 2019 08:32 AM
rochman
Audio Systems
Feb 10, 2019 07:58 AM
Geary Thomas
Audio Systems
13
Mar 2, 2018 04:29 PM
sevitz5
Audio Systems
17
Oct 30, 2016 07:21 AM
