Help trouble shooting please.
Old Mar 25, 2013 | 03:45 PM
Molarman's Avatar
Molarman
Originally Posted by BigD9485
Molarman, where did you have your ground and what did you do to correct your ground?
There are two tapped but unused hole on the lower triple tree facing the seat. I used one of these. The first time I don't think I removed enough of the paint and the supplied connection was a little flimsy. I removed the attachment that came on the ground wire and crimped on a more sturdy connector, sanded the area a little better and reattached. I have not changed the fuse yet so I will tonight and hopefully it works.
Old Mar 25, 2013 | 08:31 PM
Molarman's Avatar
Molarman
So I pulled the fuse and sure enough it was blown. Biketronics sent me a 15amp fuse by mistake. I swapped a 30amp fuse and it's fine. Damn this system rocks! Half volume in my garage and my ears were hurting.
Old Mar 25, 2013 | 09:11 PM
mtgriz's Avatar
mtgriz
Thanks for the update...been looking forward to it because I'm considering the same setup for mine. Did that amp set on top of the HK head unit alongside the CB module, or did you have to relocate the CB? Also, wonder about the comment where the AVC could be a complication.
Old Mar 25, 2013 | 09:25 PM
Molarman's Avatar
Molarman
I relocated the CB module underneath the HU with industrial strength velcro. I dont know about the AVC yet since I have not been able to ride it since install. I would think the only complication could be inadvertently overdriving the speakers. I will be posting pics of the install. Overall it was a straight foreword install.
CoachKenB
Audio Systems
15
Feb 26, 2019 07:44 PM
GLYDN
Audio Systems
Sep 26, 2016 12:10 PM
Vision
Audio Systems
86
Feb 22, 2016 02:33 PM
kishstl
Audio Systems
May 24, 2014 06:54 PM
Jetblack3
Audio Systems
16
May 8, 2014 07:07 AM
