UltraNutz - you sir are a fountain of amazing info. I'm on a 2011 FLHX, doing a very similar upgrade as most folks here. I received the amp today, SS 4520 and am trying to decide which speakers. I keep hearing the Polk 6.5's but which ones? What is gained by going with the Titan II besides a much bigger price tag?
with that amp you want to stick with the Polks because they are 2.7 ohm and more closely matches the amp for optimum ouput. Wire them to the front channel of the amp and you'll be tickled with that. Make sure to wrap those speakers in polyfil before putting the fairing cap back on.
Just received my Polk MM651's and saw in the instructions information about setting "Tweeter Attenuation Switch" , then looked at the crossovers and don't see any switch....must be referring to a different speaker set??
Ultranutz, I've been reading your name all through this forum as the audio guru. I'm doing an amp and speaker upgrade on my 12 street glide and am going with your rf amp and Polk speaker setup. If you recommend it, I'll try it. Thanks.
Now the big question, how difficult is the install? Not completely mechanical inclined. This is my baby and don't want to do more damage then good. You need the service manual for fairing removal? Or any chance you know of a good audio installer on Long Island? Don't want to use the dealer either
