Class D AMPS and FM reception issues
Old May 25, 2013 | 08:56 PM
  #121
springer 03's Avatar
springer 03
What about the 100 mHz choke that was supposed to cure the FM reception problem? No go??
Old May 25, 2013 | 09:01 PM
  #122
Winkokid's Avatar
Winkokid
didnt try that yet. i would like my full fm reception... prolly try that as a band-aid
Old May 26, 2013 | 07:31 AM
  #123
springer 03
I have one on the way from mouser. Should be able to post results in a couple of weeks. I thought mine was O.K. after going back to the original mast antenna and burying it under the rear fender strut. After riding it this week the F.M. reception isn't good. I can still get the stations but they are weak and fade out with poor quality. Maybe I'll try the powered antenna I removed and see how or if that helps. The MP3 discs sound great but I need my F.M. too.
Old May 26, 2013 | 07:43 AM
  #124
springer 03
One other thing to mention is that I'm having the reception problem across the whole fm band. From the high 80's to 107's, so I'm not real sure killing the 100 mhz emf's on the power wire is the answer, but it's worth a $10 bill.
Old May 26, 2013 | 10:31 AM
  #125
Dew Me's Avatar
Dew Me
Originally Posted by Winkokid
update.... rf prime 400-4 ........
too big!!!
Hits the faring ....
Oh well, now we all know!!
****!!! I rolled the dice and bought it 2 days ago. It'll be here Tuesday or Wednesday. Guess since it is already coming I'll go ahead and try. Maybe I can figure out how to shave the backside of the gauges to make more room. Or if I'm feeling really ballsy maybe grind off some of the amp body. I reeeeally doubt that though. I bought it from Amazon so returning it should be pretty painless.
Old May 27, 2013 | 02:48 AM
  #126
sl33py's Avatar
sl33py
Adding possible FM issues for the Massive BX2. Definitely lost one station (smaller local so not a surprise). Need to test to see how many more are impacted. Other radio stations came through ok.
Old May 28, 2013 | 08:46 AM
  #127
Gone Riding's Avatar
Gone Riding
Springer, the ferrite core should absorb and block interference from about 1 MHz all the way to 300 MHz. It won't eliminate it completely, and from your description your amp is worse than many. Please let us know if the core helps. A "before and after" count of clear stations across the band would be appreciated.
Old Jun 10, 2013 | 12:36 PM
  #128
Dew Me's Avatar
Dew Me
too big!!!
Originally Posted by UltraNutZ
damn the bad luck...
Maybe not...I think I've made it work:
https://www.hdforums.com/forum/audio...d-w-polks.html
Old Jul 2, 2013 | 06:26 PM
  #129
springer 03
Well I know it's been a while, certainly more than the two weeks that I mentioned earlier but I finally got around to installing the ferrite core. I was able to get 6 wraps, (3 power and 3 ground), of #8 MTWN through the center using some soap and an awl. The FM is sounding clear in my garage and hopefully I'll get to take it for a ride and report back later.
Old Jul 2, 2013 | 09:01 PM
  #130
springer 03
Got out for a short ride and the FM is working pretty good. I didn't get to the hinterlands to see if the signal fades sooner than before but so far so good. Thanx to Gone Riding.
